Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-05-2015, 02:00 PM   #21
2014 27' FB International
Clearwater , Florida
If the trailer is 50Amp 220 Volt, who delivered the 30Amp 120 Volt cable with the trailer. Unless I am mistaken most of the 50A adaptors only pass 120 volt. Wouldn't want you to fry stuff in your new trailer.
ChuckFeldt is offline   Reply With Quote
Old 11-05-2015, 02:03 PM   #22
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
There are no 220 volt trailers or motorhomes on North America.... The only exceptions are food trailers.
50 amp service is just twin 120 legs with a common/ bonded neutral.
Old 11-05-2015, 02:05 PM   #23
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Pat Cassity View Post
Since I already have a 30amp cord from a previously wrecked TT, I thought I would save myself from having to deal with the 50 amp cord when camped at a 30amp only site. I keep my 50 amp cord in a plastic storage box in my truck while in transit. The barely over 6 lb 30amp cord would sit in the same box and be much easier deal with when setting my and taking down the campsite.
Meaning no offense, but if you had said it that way from the beginning there might have been a bit less confusion. Certainly I would have been less confused!
Old 11-05-2015, 02:05 PM   #24
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I think you are asking if you can attach a 50amp end on a 30amp cordset?
If this correct you'll need a jumper between l1 and l2 so everything "can" work.
My trailers are wired for 50 amp service but I have the ability to use a 30 amp cord without an adapter.
Old 11-05-2015, 02:07 PM   #25
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Chart
There are charts that show the configurations. It looks like usually the 220 configuration won't fit into a 110. Unless no habla has taken the pliers and bent it so it will, and kazapppp goes all your construction light bulbs...saw that one, and they did it again the next week.
https://www.google.com/search?q=elec...AcRnpDkWMjg%3D
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 11-05-2015, 04:44 PM   #26
Images: 59
What you can do is put a short piece of #10 stranded wire between the black and red terminals inside the 50a connection. There is room to do this. The terminals on the 50a end are sized to take #6 wire, so it's possible to put two #10 wires on one terminal (black) and run it to the other (red).
Of course you need to make sure you don't have any 240v appliances. But if you have any (like an English Teapot that you love) you would know this.
Shown below, the jumper is the red wire.
Name:	IMG_5964 (003).JPG
Old 11-05-2015, 05:11 PM   #27
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Looks like the extension cord may be the way to go. Having second thoughts of an adapter into another adapter. In fact, the 50 amp female to 30 amp male 25 ft cord may be an even better idea. Hopefully I can return the adapter I purchased.
RV Power Cord Adapter 30 amp Male to 50 amp twist lock female camper detachable
So this would be what you need.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 11-05-2015, 06:37 PM   #28
1989 35' Argosy 5th Wheel
1979 rgosy 27
Danville , Vermont
No, the generator connection is not the same as 30A RV hookup.
fordfarmer is offline   Reply With Quote
Old 11-05-2015, 08:05 PM   #29
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Our Honda 2000 watt companion has a 30 amp twist lock female receptacle. We have a Furrion "extension" cord with male 30 amp twist lock on one end and female 30 amp twist lock on the other. This allows a direct connection to the generator or serve as an extension cord for the normal 30 amp power cord with 30 amp female twist lock and 30 amp RV three pin male plug for a power pedestal.
Here is a link to the Furrion power cables and pigtails for nearly any situation...
RV CAMP POWER
Note there has been no sales tax or shipping charges when ordering direct from Furrion.
30amp extension cord Pat Cassity Electrical - Systems, Generators, Batteries & Solar 7 08-13-2013 10:54 AM
Can a 30AMP 240v provide 2 30AMP 120v?? VeggieBullet Electrical - Systems, Generators, Batteries & Solar 17 05-29-2013 09:28 PM
50amp for 30amp trailer? racoco Electrical - Systems, Generators, Batteries & Solar 15 08-24-2007 07:43 PM
30amp to 50amp? alfalsetto Airstream Motorhome Forums 17 08-16-2003 06:42 AM
