Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-09-2002, 07:27 PM   #1
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Red face Running Lights
Next job: Check and replace any running lights on the trailer. That is the clearance lights. Shouldn't be a problem but thought I might ask. Anyone did it yet? Any suggestions??
niftypkg is offline   Reply With Quote
Old 08-09-2002, 07:39 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
If you have the OEM lights, you can still get replacements at NAPA. They seem to have the best prices(Less than 3 bucks with bulbs) and they are usally just in a bin. Be sure to get the gaskets too. The biggest difference is that your originals may only have one bulb and the new ones will have two. It uses more current but brighter is better in my book.
I would also reccomend getting some new stainless screws to attach them as the old screws may be pretty rusty. When I have replaced lights I always cut the wire as close to the old fixure as possible. Prior to crimping on a new one I also use an anti-oxidant on the new and old bare wire. There is room between the light and the gasket for the extra wire.
It takes 10 min. per light but boy what a diffrence!
BTW if any of the old lenses are still ok save one of each, as you never know when you may be on the road and need one.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 08-09-2002, 10:31 PM   #3
sovereign
sovereign's Avatar
Profile:  mill springs , North Carolina
i found some at wal-mart too
sovereign is offline   Reply With Quote
Old 08-10-2002, 10:18 AM   #4
dienst1
dienst1's Avatar
Profile:
Images: 11
LED running lights
After polishing our 1981 Excella motorhome, Jim at Airmark decided that all of the original running lights were too corroded to reuse. He replaced them with new LED running lights, what a difference. They are super bright and draw much less current.
http://www.airstreamphotos.com/photo...scn0172_es.jpg
dienst1 is offline   Reply With Quote
Old 08-10-2002, 04:57 PM   #5
niftypkg
niftypkg's Avatar
Cornville , Arizona
Thumbs up
I would like to thank you'll for replying to my thread. Sounds ike good advice to me.
Old 08-22-2002, 06:35 AM   #6
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Problems with running lights
I have been working on my trailer lights and I think I have all of the lights working except one problem.......
When I turn on my running lights, I get bleed over to the reverse lights. I can see a dim glow in the reverse lights.
I do not have the reverse lights hooked up yet to the seven way connector at the tow vehicle.
I will be getting to that shortly, (no pun intended),
Anyway any ideas why I would be getting bleed over in my reverse lights?
Could the voltage be going all the way back through my tow vehicle.
I am reluctant to believe that the wire is shorted within the light housings but maybe......
Smily
smily is offline   Reply With Quote
Old 08-22-2002, 09:57 AM   #7
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Corrosion/Grounding
Smily,
sounds like a grounding problem to me. My experience has been that whenever there is bleed through like you call it, then there is corrosion on the grounding provisions. The negative side of the bulb that is supposed to be lit is looking for ground through the backup light somehow.
Corrosion can both inhibit the flow of current and at the same time cause false currents.
Problem is, this corrosion could be anywhere, even in the trailer connector or pigtail.
Uwe
Old 08-22-2002, 10:30 AM   #8
sovereign
sovereign's Avatar
led lites
DIENST 1
where did you get the led lites?
Running Lights Barkingspider Lights - Interior & Exterior 7 12-11-2003 08:48 PM
Rear Indicator Lights Cracker Lights - Interior & Exterior 7 11-03-2003 02:42 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 08:55 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
