Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-27-2004, 12:36 PM   #1
Jimbo
Profile:
Intelli Power 9100 help
Have a IP 9100 that does not have any output. Anybosy know where i can get a schematic for this unit? is it worth even fixing?
Jimbo is offline   Reply With Quote
Old 06-27-2004, 05:36 PM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
IntelliPower should send you a set of instructions for their unit if you call them.
Progressive Dynamics
507 Industrial Road
Marshall, MI USA
49068
tel 269 781 4241
fax 269 781 7802
Salessales@progressivedyn.com
Serviceservice@progressivedyn.com
Web Sitewebmaster@progressivedyn.com
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 06-28-2004, 06:54 PM   #3
Jimbo
Profile:
Well, that was an easy fix. A large resister broke loose from the traces. I just re-soldered the resister and is ok.....sort of. I now have 14 volts out of converter, but only 2 volts out to the battery. All fuses are good and so forth. What happened was, the camper shreded a tire up through the wheel well and cut some wires. All have been repaired as everything works except getting 12volts out to the battery. Any ideas???
Where to buy Intelli power Tin Hut Electrical - Systems, Generators, Batteries & Solar 1 04-14-2004 08:06 PM
Inteli Power 9100 Bryanhu Electrical - Systems, Generators, Batteries & Solar 4 04-12-2004 04:27 AM
Newbie needs Classic 28' power management info Dave Jenkins Electrical - Systems, Generators, Batteries & Solar 3 07-24-2003 05:11 PM
Univolt replacement with Inteli Power Craig Electrical - Systems, Generators, Batteries & Solar 6 05-04-2003 11:37 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
