Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-03-2016, 06:10 AM   #1
JackP's Avatar
1972 27' Overlander
New Haven , Connecticut
Installing 12v USB outlets
I've decided to install two 12v USB outlets to our '72 Overlander. I have available slots in my DC distribution box and will run new wiring from the outlets to the DC distribution box.
My question is, should I run the ground all the way back to the ground bus on the DC distribution box or ground the outlet to the chassis near the installation location of the USB outlets?
Thanks.
Jack
JackP is offline   Reply With Quote
Old 06-03-2016, 06:29 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I pulled the power for mine off a reading light. They are low draw so I think you can ground them anywhere that's easy.
2019 Ford Expedition Platinum
Old 06-03-2016, 06:29 AM   #3
Tincampers's Avatar
Sneedville , Tennessee
Ground is ground, I'd pick the closest or easiest place. Which plugs are you going to use?
Tincampers is offline   Reply With Quote
Old 06-03-2016, 07:46 AM   #4
Wayne&Sam's Avatar
Images: 21
I find that the adapters die fairly often, so I put in 12v cigarette jacks and plug in usb adapters. It makes it easier to change when the die.
Old 06-03-2016, 08:38 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have never heard of grounding a 12 circuit. The return path, equal to the neutral on an AC circuit, of a 12 volt circuit is the chassis.
I would just pickup any close by 12 Supply. The current you are looking at is nothing and can be added to any circuit.
2004 Excursion 4x4
Old 06-03-2016, 08:42 AM   #6
Wayne&Sam's Avatar
Images: 21
Well if you mount a device in wooden cabinetry you need to get a ground somewhere.
Old 06-03-2016, 08:49 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The negative side of the DC circuit(s) in an RV has been labelled incorrectly for years. It comes from the auto industry.
The proper term for this side of the circuit(s) is "COMMON". Since it is common to all or most 12 volt devices. Rarely is it switched. In most cases the return path is completed by using the vehicle chassis.
Old 06-03-2016, 10:11 AM   #8
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Be sure you actually need USB outlets before going to the effort.
True USB only has +5v, but many devices that plug into cigarette lighter outlets need +12v input so although they may have a micro/mini USB plug on their cigarette lighter adapters, the adapter is not stepping down to 5v.
I have at least 2 devices that have mini USB inputs, but it is 12v that is being delivered on the mini USB live pin from their adapter, and they simply don't charge/run using a true USB outlet/separate mini USB cable, as the voltage is not correct for them.
martin300662 is offline   Reply With Quote
Old 06-03-2016, 10:13 AM   #9
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
You will find 12v pairs in all sorts of places in an Airstream. Just look for a colored/white pair of wires and tap in using crimp connectors. The white wire is the negative or common wire. The draw of a USB outlet is so small that you can safely add one to any circuit.
Most 12v add-ins will have a colored and a black wire. The black wire attachesto the white wire of the trailer. I have added 4 cigarette-lighter-type outlets in my trailer so that I can use my fan pretty much anywhere without tripping over wires. One outlet is patched in to the wire feeds to the wardrobe light which was easy to access and one is under the microwave cabinet. I also added a 12v outlet in my exterior refrigerator compartment so that I can use my 12v compresor outside.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 06-03-2016, 10:21 AM   #10
John Geisen's Avatar
2005 28' International CCD
Palm Beach Gardens , Florida
You can now purchase 110V outlets that have two USB ports on the faceplate. Why not consider doing something like that. Clean easy installation. Simply replace your outlet. Just a thought unless I've missed something.
John Geisen is offline   Reply With Quote
Old 06-03-2016, 11:15 AM   #11
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Not to be mean or technical here, but don't say ground is ground beyond this discussion.
Ground is not ground, there can be a potential difference in ground, that is why it is always best, to ground all the same spot especially for highly technical devices.
cazual6 is offline   Reply With Quote
Old 06-03-2016, 12:31 PM   #12
Naples , Florida
Many DC electrical problems can often be traced to ' a bad ground' or negative lead, which is an essential part of any 12 VDC circuit.
For this reason, I rarely (if ever) use the chassis or frame for a negative (ground) connection in a DC circuit, preferring to 'home run' all of my DC cables to a single point ( bus bar, binding post or terminal block) for both positive and negative cables.
Far easier to troubleshoot if there ever is a problem and provides a single place to look for them.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
lewster
Old 06-03-2016, 01:28 PM   #13
Seattle , Washington
USB is 5 volts DC - not 12.
vito98103 is offline   Reply With Quote
Old 06-03-2016, 01:42 PM   #14
Contributing Member
Pahaska's Avatar
Yes, but USP outlets for Rvs hook to 12v and reduce the voltage internally to 4v.
John W. Irwin
WBCCI #9632
Old 06-04-2016, 05:38 AM   #15
Tincampers's Avatar
You are right. In this application, I would also run a pair of wires to any device I was installing a tie into a common point such as bus bars.
Old 06-04-2016, 06:20 AM   #16
Wayne&Sam's Avatar
Images: 21
I hope someone from England chimes in using the term "earth" just to add to the semantics discussion.
Old 06-04-2016, 07:39 AM   #17
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
FWIW, I did extensive rewiring in our 2009 FC. From this I can tell you that Airstream direct wires all 12V DC devices back to the ground bus. They also install a ground post on each major section of the body to which they run a 10 gauge 12V ground wire (white insulation).
So I would follow Lewster's advice above and ground thru wiring. Yes, the frame and its sub components are grounded but Airstream, over the years, has found it cheaper, in fielding customer warranty claims, to invest in ground wires instead of relying on chassis grounds.
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 06-16-2016, 09:03 AM   #18
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands , Illinois
Cool All other grounds go to the fram of the rig so U can do the same
Thanks.
Jack
All grounds go the the chassis so U can do the same and or the body.
rmatkovich is offline   Reply With Quote
Old 06-16-2016, 01:07 PM   #19
Trnpk Crsr's Avatar
Baltimore , Maryland
[QUOTE=John Geisen;1801223]You can now purchase 110V outlets that have two USB ports on the faceplate. Why not consider doing something like that. Clean easy installation. Simply replace your outlet. Just a thought unless I've missed something.[/QUOT
USB ports that are part of AC outlets convert the AC to DC to power the USB ports. This is ok when hooked up to shore power. But if you are not on shore power, it is a very inefficient use of your inverter. Using 12 volts DC that is reduced to 5 volts DC is a much more efficient use of power.
Trnpk Crsr is offline   Reply With Quote
Old 06-22-2016, 06:55 AM   #20
gator.bigfoot's Avatar
KW , Ontario
Never assume ground is ground. I'm glad others see the value of actually running a complete circuit. I get even more anal by insisting upon a star configuration for ground and only with stranded wire.
I spent years trying to teach people this. It gets even more fun when you see 4000 volt spikes between ground and common. Good thing trailers only have 12 volts.
The value of good electrical practices should never be under estimated.
gator.bigfoot is offline   Reply With Quote
12v
USB & 12v ports in 2016 EB27 RivetingTrvl Eddie Bauer - All Models 5 05-24-2016 11:54 AM
Leviton USB 120V Outlets KJRitchie 2006 - 2010 Classic (all lengths) 14 03-31-2016 08:03 PM
12v to USB adapters that will work at float voltage Jammer Electrical - Systems, Generators, Batteries & Solar 9 03-14-2015 11:16 AM
GCFI Outlets with Integrated USB trekerboy Electrical - Systems, Generators, Batteries & Solar 5 03-04-2015 04:49 AM
120 Volt outlets w/USB ports PA BAMBI II Electrical - Systems, Generators, Batteries & Solar 3 06-30-2014 05:52 AM
