Old 02-25-2007, 12:13 PM   #1
BigDill's Avatar
1975 20' Argosy 20
Ruth , Mississippi
fuse panel question
Hey yall, where might I find the fuse box in my 75 argosy MH??
My control panel is not working and thought I would start there. It was working until just recently. The generator switch still works but nothing else. Any help would be appreciated! Thanks
Kim
BigDill is offline   Reply With Quote
Old 02-25-2007, 01:56 PM   #2
Retired.
. , At Large
The fuse panel should be on the Univolt, probably in the bathroom.
Old 02-25-2007, 02:09 PM   #3
1976 25' Caravanner
Campton , New Hampshire
check to see if there is a fuse at the control panel , my '76 has one on the side , it just screws out . Good luck
ticki2 is offline   Reply With Quote
Old 02-26-2007, 12:46 PM   #4
BigDill's Avatar
1975 20' Argosy 20
Ruth , Mississippi
Hey...I found it! I don't have any idea what a univolt is but the fuse box was in the bathroom like you said Terry. I had already checked the fuse at the control panel and that wasn't it. It WAS a burnt fuse, thank the Good Lord. I can fix that!! Thanks for your help!!
Kim
Old 02-26-2007, 01:30 PM   #5
Retired.
. , At Large
Kim
The Univolt is the power converter that makes 12v for the lighting, fans, and charges the batteries.
It can be located by following the loud HUMMMMMMM when plugged in to shore power. Most people remove them for use as boat anchors, and replace them with electronic (quiet) converters. Doing this can also extend battery and 12v equipment life.
Old 02-26-2007, 02:52 PM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Terry-
Would that be the dynomo hummmmmmmmmmmmm?
Rick
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-26-2007, 07:45 PM   #7
BigDill's Avatar
1975 20' Argosy 20
Ruth , Mississippi
Hmmmmmm, sounds like a good project for the future......after I lose half my body size and learn to contort! My Univolt is located on the lower inside wall of my bath cabinent. Some little skinny doublejointed feller must have been the installer! But I'm sure there's an easier way. When I get ready to change I will do a search here on the forum.
Kim
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 05:45 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
Control Panel indicators smily Electrical - Systems, Generators, Batteries & Solar 3 07-26-2002 03:55 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
