Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-19-2013, 08:55 AM   #1
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Blue light on shore power cover plate
Does anyone know what the blue light on the shore power cover plate indicates? It's is one a newer airstream. I've searched the forum and don't see anything. I noticed this weekend the light was on and off intermittently while charging my batteries, but I know the trailer was getting power. I'm trying to find out if something is happening or if the light is a simply an indicator and the light is going out.
Landrum is offline   Reply With Quote
Old 08-19-2013, 09:21 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The Furrion website indicates that it simply tells you when voltage is present. If yours is blinking it is either a defect or your voltage source/connection has a problem.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-19-2013, 11:07 AM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Both of my LED lights died after about 6 months.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-19-2013, 12:09 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
They are on both front and rear cover plates and the power cord. Yes, indicates a voltage is present but not how much.
We've used it camping for at least 12 months and they all still work. Handy, if it fails I wonder if the LED is replaceable?
doug
Old 08-20-2013, 06:21 AM   #5
BAB
BAB's Avatar
2015 30' Classic
Nope. After my first one failed I removed the unit to find there was no way to replace the LED -- maybe if you sent it back to Furrion, but "no user serviceable" options. The answer is to buy a 25' power cord that has the LED in the plug (male fitting).
_________________
ProPride 3P
AIR# 58452
Old 11-17-2015, 08:59 PM   #6
2004 22' International CCD
2015 30' International
Box Elder , South Dakota
I just had the same problem with my new AS -- but I was also losing power. Has anyone here found the lack of a blue light when power is is present to indicate a larger problem? I'm concerned my entire electric system is about to fail...
While camping in cooler weather, and using a lot of current, the 120v power kept blinking off for brief periods. (but no breakers popping). When I went outside, I found my Furrion cable had a good blue indicator at the park's power connector, but the blue LED on the lid on the AS power connector receptacle had gone out even though power was flowing.
lbdesign is offline   Reply With Quote
