Old 02-18-2016, 04:27 PM   #1
1975 31' Sovereign
West Liberty , Kentucky
Battery Placement
My 1975 AS 31' has 1 battery located in a compartment under the kitchen cabinets. I want to put an additional 12v battery somewhere and hook the 2 batteries in parallel. I was thinking of putting 1 battery under the couch in the front of the trailer and running the wires in conduit under the trailer to the current location and hooking it to the existing battery or placing 2 batteries under the couch up frond and running the wires to the inverter under the kitchen. Which way di you think I should go?I will be using gel batteries.
Air4563 is offline   Reply With Quote
Old 02-18-2016, 06:56 PM   #2
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
I hope you are changing or have already changed out the converter / charger to a 3 stage one that is compatible with gel cell batteries. The original Univolt converter was designed for flooded wet cell batteries that can be topped up when the water is boiled off. They kill maintenance free batteries.
Gearheart is offline   Reply With Quote
'72 Safari: Battery placement Debnw Electrical - Systems, Generators, Batteries & Solar 5 05-16-2013 07:45 PM
Battery placement Silver Streak mrcjdunne Vintage Kin 2 10-21-2012 10:25 PM
Battery placement for '65 Caravel teeraniti Batteries, Univolts, Converters & Inverters 8 01-17-2010 05:50 PM
Battery Placement Retrofit Tom Bray Batteries, Univolts, Converters & Inverters 2 09-12-2007 07:11 PM
Extra Battery Placement JaceBeck 1997 - 1999 Safari 16 10-02-2002 01:03 PM
