01-22-2013, 04:54 PM
Free Range Human
2012 25' FB Flying Cloud
Haines
, Oregon
Battery Draw Down - LP Detector
Hi Folks,
Does anyone have a rough estimate on how long it should take for the LP detector to draw down the batteries when the trailer is in store mode? The batteries are two Interstate deep cycle group 24s, 550 cca, and are probably about 1 1/2 years old. The trailer is a 2012 Flying Cloud 25FB.
I've had the batteries go flat twice. About 2 months (or slightly less) ago, I first discovered it. I charged them, then put the trailer back in storage mode. This morning, the batteries were flat again. We have had some cold weather recently, which would have some impact.
When I spoke with the maintenance department at the dealership, they said that was roughly a normal period for the batteries to be drawn down. If that is the case, I guess I could either pop the fuse for the LP detector, or disconnect the ground lead on the batteries, or just remember to charge the batteries more often.
Your thoughts?
Drathaar
01-22-2013, 04:57 PM
Retired.
, At Large
You should have gotten a copy of the Newbies Guide when you bought your new trailer. Parasitic draws were discussed there, and the LP detector was specifically mentioned, with a time frame for how long before the batteries would go dead in storage.
01-22-2013, 05:02 PM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Soon Enough
Somewhere between the second and third week for me.
I rewired it so it is turned off with everything else when the battery isolation switch is turned off.
If a propane detector detects propane in an empty Airstream, and there is nobody there to hear it; does it still make a sound?
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
01-22-2013, 05:09 PM
Free Range Human
Haines
, Oregon
Originally Posted by Alumaholic
Stuff clipped....
That depends on the magnitude of the explosion when the spark meets the propane.
Thanks all, I will dig out my Newbie Guide...
01-22-2013, 05:15 PM
2010 22' Interstate
Anchorage
, Alaska
Drathaar, if you've run your batts flat, twice, they are now seriously and permanently compromised and will no longer have their rated Ah capacity. As a general rule, FLA or AGM batteries shouldn't be drawn down to less than 50% SOC. This is about 12.4 v. at 70 deg. F. In addition, if a FLA battery is totally drained it will freeze very easily and probably break the case. My MO for when my rig is in storage; I either: 1) remove the batts and put them in the garage on a maintenance charger, or 2) leave the batts in place, turn off the battery disconnect switch and connect them to a maintenance charger.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
01-22-2013, 05:23 PM
Albuquerque
, New Mexico
What Spark?
... your battery is dead, remember?
Anyway, I still pull my batteries and keep them on a Battery Minder at home if my Airstream is going to be sitting, unused for 3 weeks or more. I could not be more pleased with the Model 12248 Charger-Desulfator-Conditioner.
Happy Trails!
01-22-2013, 05:29 PM
Free Range Human
Haines
, Oregon
Ken, thanks for the recommendation on the charger. Much appreciated.
01-22-2013, 05:35 PM
2010 22' Interstate
Anchorage
, Alaska
"... your battery is dead, remember? " Huh?
I have two of these smart chargers from Ctek: Battery Chargers - CTEK Battery Chargers
They have worked flawlessly for me. I leave one on my Interstate (parked in Sisters, OR) for months at a time. They are a little less expensive than the one Ken suggests. List $150, but $105 at Amazon.
- wayne
AIR #44779
TAC AK-1 !!
01-23-2013, 09:03 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
LP Gas detector has a 1-amp in-line fuse, and so should draw no more than 24 amp-hours per day from your house batteries; probably a lot less since it would only draw anything close to a full amp while the alarm is blaring.
When you pop the fuse, take advantage of having a de-energized circuit to wire in a switch into the system, so that you don't have to pull the fuse again; just switch off. Then put a note by your propane tanks, "Turn on LPG Detector" to remind you to switch it back on whenever you open the valves on your tanks.
01-23-2013, 09:44 AM
2008 16' Safari
Destrehan
, Louisiana
The batteries will discharge all by them selves after several months without a charger on them. The LP detector draws less than the normal battery discharge rate. If you store the trailer for months without any attention you need to use something to keep them up.
You have lots of choices. Smart battery charger, battery minder, solar cells or even take the battery out and keep it at home. Your choice.
01-23-2013, 02:42 PM
Wise Elder
2010 30' Classic
South of the river
Originally Posted by Drathaar
Hi Folks,
The LP detector draws around 150 mA or around 3-4 AH per day. It would deplete the charge on a pair of group 24s in about two weeks, maybe more.
I removed my LP detector because I don't believe it solves any problem that I actually have, though I don't necessarily recommend that sort of thing. Do your own research, make your own choices.
Even without a propane detector the batteries should be charged every month or so.
01-25-2013, 12:16 PM
2008 16' Safari
Destrehan
, Louisiana
My LP detector is listed as using 0.010 amps in monitor mode. That is a total draw of 0.25 amp hours per day. Most batteries are good for about 60 amp hours. That would be 120 days before the battery is drained from the LP detector.
As I said before; all lead acid batteries will discharge internally. That is normally about 60 days. (give or take)
Ignore the LP detector, it makes little to no differance.
Just tend to the battery in any way you see fit.
01-25-2013, 01:12 PM
Albuquerque
, New Mexico
Concur With Your Calculations, but
... direct experience suggests that the LP detector may draw a bit more than the literature suggests.
With the propane detector, my batteries would last 2 to 3 weeks, and they were dead, really dead.
Once I wired LP detector behind the battery isolation switch, the batteries stayed charged well beyond a month.
Perhaps it's the combination of LP detector and normal discharge rate.
As I posted earlier, I routinely pull my batteries out of the Airstream and put them on a Battery Minder for maintenance charging and desulfation.
All the best!
01-26-2013, 07:19 AM
2008 16' Safari
Destrehan
, Louisiana
I keep my trailer pluged into a 120 vac source all the time. I did this after my batteries went flat and would not recharge. No more problems since.
FYI - My trailer has an external battery box. It filled up with rain water once and killed the batteries. I drilled a couple of drain holes in the bottom and haven't had anymore trouble.
01-26-2013, 09:19 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I've forgotten all about having an LPG leak monitor, consequently, it doesn't drain the batteries at all.
01-26-2013, 10:56 AM
Master of Universe
2008 25' Safari FB SE
Grand Junction
The propane detector is not the only source of phantom loads. On ours, the subwoofer is always on; I installed a switch and turned it off. If you leave the tank and battery monitor on, that will draw some current. If you forget to turn off the antenna booster, that will draw more current.
Since batteries discharge over time anyway, the advice to put them on a charger regularly is the best advice.
Gene
01-26-2013, 03:56 PM
From All Over
Dumb question for the OP… When your battery isolator is switched off, will the battery still charge from shore power? If so, then your converter, or inverter/charger, or whatever, bypasses the battery isolator.
I consider it a dumb question becasue it's pretty obvious that Airstream trailers aren't wired the same as Airstream motorhomes. What I'm thinking of might not apply to you, but if it does…
I ask because if you have an inverter/charger to power your AC appliances from your house batteries while boondocking, you may have parasitic drains on the AC side. I found that out the hard way with my Interstate. With my DC side switched completely off and the inverter switched to "invert", I still have 120vAC power to my televisions, microwave, and 12vDC/120vAC refrigerator. I have to be sure when I place my unit into storage that I switch the battery isolator to off, and switch the inverter/charger to either "off" or "charge only."
02-06-2013, 05:27 PM
Free Range Human
Haines
, Oregon
We are solving the problem tomorrow. I am putting a 150 watt solar panel on top, with a 30 amp internal controller. We went with the Zamp unit.
02-12-2013, 07:36 PM
Free Range Human
Haines
, Oregon
A follow up. I picked up the trailer yesterday, after having the solar panel installed. Out of curiosity, I wanted to see the installation of the panel and how the wiring was brought into the interior. What I saw, I didn't like!
The service techs routed the cable down the back side of the refrigerator, which is OK. What was not OK was the rough hole that was cut, with the wiring chafing against it. It was also chafing on a metal fin between the refrigerator and the AC unit.
I sent photos to the service manager, and will be taking it in tomorrow to have grommets and clamps installed to keep things from chafing.
I suspect that many Airstreams may have their solar panels installed in a similar manner. You may want to check yours. If the positive lead from the panel chafed through and made chassis ground, it might fry your panel. There is supposed to be a fuse between the panel and controller, but if it shorts above the fuse, it is a moot point.
