Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-12-2013, 09:10 PM   #1
1995 34' Land Yacht LE
New Carlisle , Ohio
Unhappy '95 34' motorhome -- starting problem
My motorhome has the 454 chevy engine...when trying to start it, the dash lights come on, but immediately trip something and whole system goes dead..there is a click noise, but have been unable to locate...any thoughts..thankx..
auxier61 is offline   Reply With Quote
Old 08-12-2013, 10:06 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
If you have a solar panel it will run the dash lights with a dead battery?
Have you got good battery connections?
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 08-13-2013, 04:08 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The dashboard lights use a lot less power than the starter. Your dead battery could have enough power to light the dash, but not enough to start. When you turn the key all the way to "start" the dashboard lights might go off because they "brown out" due to the extra draw from the starter.
The clicking noise is probably the starter solenoid (AKA the Bendix). That's the electromagnet that causes the starter gear to engage the teeth around the edge of the flywheel.
So, either a dead battery, or bad battery terminal connections.
Old 08-13-2013, 04:44 AM   #4
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Sounds like a bad battery indeed. The second the starter starts drawing power, everything else goes dark.
andreasduess is offline   Reply With Quote
Old 08-19-2013, 11:35 PM   #5
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
Make sure that you check your battery and starter connections for tightness and be sure they are clean.
LJH is offline   Reply With Quote
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 51 08-12-2013 10:50 PM
Brake controller adjustment problem Zettervall Brakes & Brake Controllers 9 08-30-2011 07:58 PM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
