Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 11-06-2009, 10:54 PM   #15
redhawkerII's Avatar
Profile:  1970 27' Overlander
Altus , everywhere GREAT
Images: 14
Send a message via Yahoo to redhawkerII
Our Frige is electric and Propane driven...We were really surprised that the propane part of it worked. Down below- a toggle switch and a gas line valve switch...with a long 'contraption' That has a flint inside it, and if you get it in there right, you twitch/flick it while holding down the pea sized red button...then you hear FOOOM! and hold button some more then let off. If the gas part of your refrigerator works, then you lucked out. But good luck getting it all together---all the others are right, and once you do get something figured out and fixed-it will last a long long time.
.....Is there another word for synonym? " Life is like a bicycle...to keep your balance you must keep moving." Einstien, 1930...and lastly,-"Go confidently in the direction of your dreams, Live the life you,ve imagined"...Henry David Thoreau
redhawkerII is offline   Reply With Quote
Old 11-07-2009, 08:37 AM   #16
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
WELCOME POE
From another ole person. Just stay tuned here and please remember "THE ONLY STUPID QUESTION" is the one U DONT ASK.
There is a wealth of info here from those who have BEEN THERE,DONE THAT. Use the search features when possible.
Glad to have y0u with us.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336
My your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 11-08-2009, 03:07 PM   #17
poe
Profile:  1965 22' Safari
Sodus , New york
Roger, the person who helped me regarding the stove
Roger-
Yes you hit it on the head - I have absolutely no knowledge about that ammonia absorptioner) stove in my AS. Its a Dometic gas-electric.
The electric doesnt work (turn off gas line & turn on electric switch and put thermostat on 4), hmm, don't know if I turned the other black dial to 0 or not. running out to check. Didn't matter. Doesn't work. At any rate, same goes for the gas side - electric off, black dial to 4, gas on, hold pilot button in, make sparks with igniter and nothing happens. its alot like the main heater on the other side of the AS - hold pilot in light match - nothing happens. If the 4 burner gas stove didn't work so well I'd be sure there was a gas turnoff valve I missed somewhere.
poe is offline   Reply With Quote
Old 11-08-2009, 04:29 PM   #18
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Send a message via ICQ to Aage
poe,
Don't have my service manual at hand just now, but EVERY gas device in an AS has its own shut-off valve, usually in a fairly obvious place, but also sometimes on the underside of the trailer.
Would suggest you find the one for the refer before going any further...
The road to a friend's house is never long. (Old Danish Saying)
Old 11-10-2009, 06:28 PM   #19
poe
Sodus , New york
yup, keep tryin stuff.
Never could get the main heater pilot to work (days of trying), so finally just blasted it with butane torch and keep pilot valve down and it worked!!
Same treatment never revived the refrig tho so I'm poised to rip it out and install new 110 v electric unit from Loews (for $175.). Thanks for your commentary & spirit.
Old 11-10-2009, 06:44 PM   #20
poe
Sodus , New york
Success with main heater pilot - so Poe 14 - Air Stream Problems 42
Wild, never did find another shutoff valve for the main heater, but followed my brothers (Navy Jet Chief Mechanic) advice and blasted the pilot with Butane torch and it burned off and kicked into action - I NOW HAVE HEAT!! You just gotta try it all. And many thanks for your thoughts and time.
The same procedure did NOT work however on the dam refrig!! But that is not quite as important here in the northcountry !! !! Hey thanks for your information from your experience & perspective.
Originally Posted by Aage View Post
poe,
Pea sized hail...(whew!!) redhawkerII Off Topic Forum 8 03-24-2009 07:44 PM
And Yet Another New Person ddennis2 Member Introductions 3 06-20-2007 10:47 AM
Hello, new person. bill pimente Member Introductions 3 12-21-2006 06:04 PM
Do you know this person? Tikiman Our Community 50 04-13-2006 07:59 PM
WHEW!!! Tank Stench... Jabba Waste Systems, Tanks & Totes 8 06-15-2003 11:53 PM
