I recently aquired a 1962, 28' Land Yacht Ambassador that is in good shape. I do however have a couple of windows that need replacing and am having a difficult time figuring out how they come off without causing more damage. It appears as if you would lift the window upward, then slide out but, they dont budge. Can anyone help? Thanks
After removing the window openers there is a phillips head screw on the outside in the center that needs to be removed before you can lift the window and slide the window off.
Welcome
