Old 10-19-2016, 04:08 PM   #1
1962 30' Sovereign
Wasilla , Alaska
Hello from Alaska
Hello from Wasilla, AK. This looks like a very active site. I've been reading about restorations. We have a 1962 AS Sovereign. It came along with my partner. She used to use it for travelling around the state to dog shows. It's mostly original inside with original appliances that worked when she last used it about 10 years ago. It's been used for storage since then. Not too bad outside. I think we will need to gut it to deal with wiring issues. She says when she had it plugged in to 110 she would get shocked sometimes, so had to be careful what she touched. But I guess the first step is to get all the stuff moved out that doesn't belong in there. Anyway, we are looking forward to making it usable again.
Wulfslaed is offline   Reply With Quote
Old 10-19-2016, 04:24 PM   #2
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
This problem may simply be the plug on the power cord is incorrectly wired, no gutting required. Very easy and innexpensive to replace.
Good luck with the cleanup!
Al Boondy is offline   Reply With Quote
Old 10-19-2016, 06:36 PM   #3
GeocamperAS's Avatar
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Welcome to the forums.
If you have the time and drive to do the work, gutting it gives you a clean slate. You can change the layout. Also, as with most campers sitting around that long, mice move in and nest in the insulation in the walls.
Al Boondy could be right about the cord. However, when I gutted mine I found mice had chewed some 120 volt wires.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 10-20-2016, 02:37 PM   #4
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
Welcome to the forums from Pennsylvania. We hope you enjoy your project as much as we've enjoyed ours. We used our second Airstream for storage for a couple of years before we started restoration this spring. So, I agree your first step is to remove all the stored material and assess what you have. You should expect to see some rodent and insect debris and possibly damage, but that fades quickly as you get going on the project. Gas appliances seem to attract both types of critters. We had a mild shock issue on our first trailer that we tracked down to the outside receptacle.
We've found the folks here on the forum very helpful when questions arise. Someone here has been there before and is willing to offer advice and sometimes what "didn't" work for them.
Good luck and please post some photos as you progress. If interested our most recent project is discussed at; http://www.airforums.com/forums/f394...er-155180.html Many of the ideas came from reading the forums.
Roy and Marie
64airstream is offline   Reply With Quote
Old 10-24-2016, 10:02 PM   #5
1962 30' Sovereign
Wasilla , Alaska
Photos
I got some photos today.
Old 10-24-2016, 10:07 PM   #6
1962 30' Sovereign
Wasilla , Alaska
I will be documenting this renovation in the 1960-1964 Sovereign Forum.
http://www.airforums.com/forums/f524/
Old 10-24-2016, 10:09 PM   #7
FCStreamer's Avatar
2014 30' Flying Cloud
It's beautiful! Thanks for sharing!
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Hello All! Newbie here just wanted to say Hello! star Member Introductions 4 08-03-2012 09:08 PM
alaska shock norbert Our Community 4 08-24-2008 12:02 PM
Just want to say hello. So, Hello AirstreamAZ Member Introductions 13 01-10-2007 08:24 PM
Hello hello SeanClaes Member Introductions 9 01-30-2006 06:58 PM
Alaska PeterH-350LE On The Road... 11 09-04-2002 07:57 AM
