Old 06-24-2014, 10:15 AM   #1
1993 25' Excella
CLeveland , Ohio
Which Flooring? See pics!
Hi, Went to Home Depot to look at the plywood for our subfloor. WHich one would you suggest? See the four pics below. Thanks in advance!
Use Pressure treated? :
Akronguy is offline   Reply With Quote
Old 06-24-2014, 10:32 AM   #2
chilipepper's Avatar
1971 27' Overlander
Dickinson , North Dakota
My understanding is a definite NO to pressure treated as the chemicals do not play well with aluminum. I just replaced the rear subfloor in my '71 and used ACX and treated it with Smith's Marine Epoxy from Vintage Trailer Supply. I think the thickness you'll want to measure what you have and match it as close as possible. I'm not sure what the standard floor thickness in a '93 is. I hope that helps!
Ryan Jilek
WBCCI 7165 | TAC ND-3
Ms. Streamy - 1971 Overlander Restoration Blog
chilipepper is offline   Reply With Quote
Old 06-24-2014, 04:11 PM   #3
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
We used 3/4" marine plywood. It is an exterior (more waterproof) glue and all the voids are filled. Its not available at HD or Lowes, but almost any lumber yard can get it (or order it) for you.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 06-24-2014, 04:52 PM   #4
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 101
Shari
Ditto - same here. You may also be pleasantly surprised at the price of ply from a real lumber yard...
One final thought - regardless of the ply you use be sure to seal the edge cuts before you install. Open edges are a great wick for moisure
1964 Globetrotter | 2023 Nissan Armada
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 06-24-2014, 05:41 PM   #5
1993 25' Excella
CLeveland , Ohio
The original subfloor was one piece The area I am talking about is around the equivalent of a 4 x8 sheet, not the entire 25 foot trailer. I am welding the steel frame for reinforcement purposes. There is rust on some of the frame. There is no way to put the plywood back in one piece. Thats why I asked about putting down the 1/2 inch in 3 pieces and then 1/4 inch in a much larger piece. See pic.
Do you see what I see? Foiled Again Airstreams on eBay 3 12-28-2011 04:51 PM
Need to see pics of med cabinet rverforlife General Interior Topics 1 05-10-2011 12:05 PM
Which Flooring???? AndyPenny Floor Finishes 29 09-18-2008 03:26 PM
Lets see your travel pics! Boondocker Off Topic Forum 5 12-28-2005 04:40 AM
Profile Pics - we want to see you! Janet H Forum Admin, News and Member Account Info 32 10-26-2005 08:42 PM
