Old 05-16-2012, 06:53 AM   #1
BrockLives's Avatar
1972 29' Ambassador
Currently Camping , Pennsylvania
Trim/Moulding Around Floating Floor?
How can and where do you attach trim around the edges of a floating floor? Or, how do you finish the edges if you don't use it?
I put cork down with a 1/8" margin around the edges, but don't know what sort of trim options I have since I can't nail or screw into the aluminum walls.
BrockLives is offline   Reply With Quote
Old 05-16-2012, 07:18 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Glue. Cove base adhesive to wall.
dwightdi is offline   Reply With Quote
Old 05-16-2012, 08:07 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
The only place I use silicone adhesive on the Airstream. Under the cove or 1/4 round. It seals to the floor, keeps spilled liquids away from the walls and it allows for easy maintenance. Besides, if you fill the expansion space at the edges it allows for that expansion .
Old 05-16-2012, 06:08 PM   #4
BrockLives's Avatar
1972 29' Ambassador
Thanks guys
