-   -   Trim/Moulding Around Floating Floor? (https://www.airforums.com/forums/f36/trim-moulding-around-floating-floor-91220.html)
BrockLives 05-16-2012 06:53 AM
How can and where do you attach trim around the edges of a floating floor? Or, how do you finish the edges if you don't use it?
I put cork down with a 1/8" margin around the edges, but don't know what sort of trim options I have since I can't nail or screw into the aluminum walls.
dwightdi 05-16-2012 07:18 AM
Glue. Cove base adhesive to wall.
Melody Ranch 05-16-2012 08:07 AM
The only place I use silicone adhesive on the Airstream. Under the cove or 1/4 round. It seals to the floor, keeps spilled liquids away from the walls and it allows for easy maintenance. Besides, if you fill the expansion space at the edges it allows for that expansion .
BrockLives 05-16-2012 06:08 PM
Thanks guys :)
