Originally Posted by absteen
As to the sub floor movement; they use plywood because it does NOT expand nor contract. The grain of the layers are laid perpendicular to each other, and therefore it will not move at all.
With changes in its internal water content, wood will expand and contract across and parallel to the grain. The changes parallel to the grain are only a fraction of those across. The cross-laid structure of plywood takes advantage of the small changes parallel to the grain, but those changes do occur. To change from no squeak to squeaking can be due to shrinkage of only a couple of hundredths of an inch over several feet of plywood. The thickness of plywood will also change with moisture content, but would probably not cause squeaking.
The point? I don't think Waninae39's squeaks are important.
Tiim
