01-07-2013, 06:56 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Marmoleum Installation
I have tried numerous floor treatments, many with questionable results...having seen some nice flooring jobs with marmoleum I'm going to give it a try. For those that have marmoleum in your trailers, did you install it yourself or have it installed. I want to go with sheet marmoleum in our "74" Tradewind but understand it only comes in 6' widths. In addition, to butt it together ("weld" together) requires special talent and tools. Anyone have experience with this? Thanks!
Indiana, PA
TAC PA-5
WBCCI 4871
01-07-2013, 07:11 PM
2008 27' Safari FB SE
Miami
We only put it in the bathroom. It has held up really well and is, of course, impervious to water. Used contact cement to lay it down and it hasn't budged.
We got our little piece from a friend's leftovers and it was originally 79" wide. They did have a seam in their application but you really had to look for it. They installed it themselves in their mud room.
Great looking stuff.
Mike
01-07-2013, 07:23 PM
Klatawa (to travel)
1965 24' Tradewind
Bremerton
We have installed Marmoleum in 3 trailers, but all while the trailer was empty of walls and cabinets. You need a near perfect subfloor to begin with. Any imperfection in the floor will show.We put the seam along the wall that would then be covered(streetside) with closets/cabinets. There are two grades, commercial and regular, surprisingly the commercial is thinner, and tears easier.
Good luck, I love the look that you get.
Klatawa
(Dave & Debbie)
1965 24' Tradewind
2015 Chev Silverado HC
01-07-2013, 07:37 PM
1993 34' Excella
Estancia
, New Mexico
Forbes, the manufacturer, is very clear you have to use their adhesive. There is also a tile marmoleum with a different adhesive. Ditto on a perfectly level subfloor. Forbes told me to screw down 1/4" piece of baltic birch to the plywood subfloor with a countersunk screw every 4" in a grid. I thought I did a good job, but a few of the screws still show. I'm still glad I picked marmoleum.
01-07-2013, 08:19 PM
1976 Argosy 24
now being enjoyed by Heath and Mary in
, Vermont
Bob,
I second everything that Lumatic and Dave and Debbie have told you.
I used Marmoleum on the floor and on the bath and kitchen counters too.
Still looks great and cleans like a breeze. Very happy with it.
Here's a couple of shots of my original install. Wall to wall like Dave and Debbie.
http://www.airforums.com/forums/f227...tml#post242846
Sergei
01-07-2013, 08:28 PM
1976 Argosy 24
, Vermont
A few more Marmoleum shots for you:
Sergei
01-07-2013, 09:23 PM
1968 22' Safari
Buda
Originally Posted by SmokelessJoe
Bob,
Sergei
I read the link you posted, it said you put in a seamless piece of flooring, does marmoleum come in 8ft widths?
DFlores
David & Diana
01-07-2013, 09:29 PM
1976 Argosy 24
, Vermont
No. Like Dave and Debbie above I butted the two pieces, about 12" or less out from the street side wall. Since cabinetry covers that entire wall the effect is seamless.
Sergei
01-07-2013, 09:30 PM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
Had it done to Bambi II. Inside is only 6' wide so no seam. Installer put down 1/4" smooth base first. He'd done 1/2 dozen Airstreams before ours. First class. Located north of Denver.
Antique Pedaler
2021 Caravel 20 FB
01-08-2013, 04:32 AM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
I love Marmoleum
Bob,
I have installed sheet Marmoleum a few times. If you can find a Pro that has all the proper tools and equipment, and is available, have a pro do it. It comes on a roll that is 2m wide, so you will have a seam. Armstrong has a line of commercial linoleum that is 12' wide, but their color choices are very limited.
Sub-floor prep is the most crucial part of the install. I first used a penetrating epoxy (ESP 155) then I used WestSystem epoxy with microlight fairing filler to "fair" the surface. I explained what/how I did it starting on post #386 of this thread. Good luck!
Lance
01-08-2013, 06:46 AM
1993 34' Excella
Estancia
, New Mexico
I chose Marmoleum because it has a vintage look. And now for a wee bit of useless information: Marmoleum is a true linoleum. What you may ask makes linoleum different than vinyl. The "lin" in linoleum comes from linseed. Linoleum is made from linseeds. I didn't know this until last year.
01-08-2013, 05:46 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Thanks for all the suggestions, advice, and tips regarding marmoleum installation. It would appear that subfloor prep is critical to a long lasting floor. Didn't think about the seam being under cabinets but since I will be removing the galley, bunks, and dinette that should be hidden upon re-installation. How easy is it to cut the marmoleum. I got to handle a piece of sheet marmoleum yesterday and it seems rather heavy.
Indiana, PA
TAC PA-5
WBCCI 4871
01-08-2013, 06:34 PM
Always learning
1972 29' Ambassador
Central
Marmoleum is not too difficult to cut as long as you have sharp cutting tools. I have the best results by scoring the sheet with a razor knife first, then using a hook blade in a utility knife like this to make the final cut. There are a bunch of good how to videos on youtube from Forbo. The best ones are in German, but you'll understand as they go along.
Lance
04-06-2014, 07:04 AM
Peapod
1985 31' Excella
Dade City
Is it possible to do a good job of installing marmoleum WITHOUT removing cabinets/appliances/beds? We want to replace our carpet - changed carpet in previous AS without taking everything out and it looked great, but we would like to go to a solid floor this time.
04-06-2014, 07:31 AM
Always learning
1972 29' Ambassador
Central
Yes! It is possible to install the Marmo without taking everything out.
How to instructions start here.
Lance
04-17-2014, 07:11 PM
Peapod
1985 31' Excella
Dade City
Wow. Just wow. What an impressive thread, and get results! Thanks for sharing.
04-18-2014, 05:37 AM
Always learning
1972 29' Ambassador
Central
You are very welcome. Sharing is what this site is all about.
Lance
