Old 11-25-2009, 09:55 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Correct procedure for checking for floor rot
I have heard to check the floor for rot around the perimeter with an ice pick.
How do you check the rear area under the bathroom sink and head?
Also a small soft spot by a front window near the door is repaired how?
bwaysteve is offline   Reply With Quote
Old 11-26-2009, 12:12 AM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
If you find rot in any other area of your trailer then I am sorry to say that you already know that rot is in the back bath areas and front window areas (because these are the areas with the most rot)!... Depending on trailer, which I still have not run across one without, They all have rot! It is a major problem with all Airstream of any size or year made!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 11-26-2009, 09:00 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
You just have to get to the areas that you can reach and make a judgment from that. Open the cabinets and poke around under the sink and work as close to the edge of the toilet that you can reach.
If you want a true test remove the belly pan and work from below.
2004 Excursion 4x4
Old 11-27-2009, 04:56 PM   #4
1963 28' Ambassador
Northern VT , Vermont
Ditto to Vinstream. Buy it expecting to replace the floor. Otherwise you're trying to draw to an inside straight. Also factor in the price of new axles, they also have a relativly short lifespan.
putback is offline   Reply With Quote
Need Help, Is this floor rot? Jezibels Buyer Guidelines 11 11-15-2009 05:56 PM
Check out my floor rot! osolow Repairing/Replacing Floor &/or Frame 24 09-11-2008 06:43 PM
77 Argosy floor rot kontiki Repairing/Replacing Floor &/or Frame 4 10-21-2006 06:09 PM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
Floor Rot mmeburges1 Repairing/Replacing Floor &/or Frame 3 01-10-2004 06:21 PM
