Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Title, VIN & Registration
Old 04-19-2017, 11:02 AM   #1
Jakattack's Avatar
1955 26' Cruiser/Overlander
Nikiski , Alaska
No ID tag on my 1954 26' Cruiser Californian Whale Tail, is there a way to get the SN
So I bought this airstream, and by looking at old pictures and brochures I'm able to confirm it's a 1954 26' Cruiser Californian Whale Tail.
My only problem is there's no ID tag next to the door like there should be.
I took a wire wheel and cleaned off the tongue and was able to find some numbers. I found 199 stamped on the frame and then the patent numbers on the front part. I've included pictures of everything.
I have heard that this model and year were only made for a short time and that only 100 were made with the SN starting at 64XX, but haven't found much to confirm that.
My question, which I'm sure has been answered somewhere, is there a way for me to identity what the serial number is using the numbers I've found?
ID:	283677Click image for larger version
ID:	283678Click image for larger version
ID:	283679Click image for larger version
ID:	283680Click image for larger version
ID:	283681Click image for larger version
Jakattack is offline   Reply With Quote
Old 04-19-2017, 11:33 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The numbers you found on the coupler are not Airstream. They are the coupler manufactures.
2004 Excursion 4x4
Old 04-19-2017, 02:01 PM   #3
Jakattack's Avatar
Nikiski , Alaska
I should have described that better, I included those incase they would some how have helped in identifying anymore information on the trailer
I know with most anything you buy now all the numbers for everything are documented some how somewhere, just didn't know if that was the case for airstream
$30,000.00 Vintage 13 Panel Whale Tail :: 1954 Airstream Wanderer Rosie Conway Airstream Registry Discussions 0 03-14-2015 04:57 PM
1954 Airstream 'Flying Cloud' California Whale Tail eBay Watch Airstreams on eBay 0 08-21-2009 10:00 PM
demystifying the whale tail - 1954 Flying Cloud greenrig 1950-1955 Flying Cloud 43 05-18-2009 11:30 AM
