Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Trailer Values
Old 09-03-2006, 10:19 PM   #1
hampden , Massachusetts
'62 Globetrotter???
Hi there! I am looking for some ballpark info on price. Camper is about 3 1/2hrs away in northern NH and I haven't gotten to see it yet, but I have pics! Camper was a restoration project that didn't get done. Interior mostly gutted except for bathroom. Supposedly has new tanks (must be grey/waste tanks because no propane tanks on it) and new wiring. Newer AC unit. Thoughts?
Amanda
ID:	25554   Click image for larger version
ID:	25557   Click image for larger version
ID:	25559   Click image for larger version
ID:	25561   Click image for larger version
azthermal1 is offline   Reply With Quote
Old 09-03-2006, 10:22 PM   #2
One more pic......
Old 09-03-2006, 10:27 PM   #3
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
What about appliances? Doesn't look like it has any...
In that case, I would say at the low end in the "As Found" range, check out the whole link, but especialy "Table A" and "Table C".
Good luck if you decide to persue it...we love our GlobeTrotter!
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-03-2006, 11:16 PM   #4
CaddyGrn's Avatar
1963 16' Bambi
1962 22' Safari
Yreka , California
Hello,
I would agree with the posting from InsideOut... also check the floor. Is it a replacement? I rather doubt it as it is painted white. Is it a second layer of plywood over the top of maybe spongy wood? If so, that means a shell off restoration. There are a few crumples I can see from the photos. Not too bad if you are handy with metal work, otherwise might get spendy. Depends on how fussy you are.
It could be a really nice trailer, however. Great size, and a lot is in there to work with. Appliances are expensive. Especially the refrigerator.
I would certainly go look at it. Have the seller show you how everything works that is there. Be sure the bath water works, etc. Make sure no leaks. See if lights work, brakes, etc.
Good luck!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 09-03-2006, 11:22 PM   #5
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Unless one has the time, tools, $$ and other resources I would tend to advise anyone to spend a little more up front and get a trailer that needs less work. It may be cheaper in the end.
If you have the time, tools and tallent, negotiate a good deal and have at it!
Fyrzowt is offline   Reply With Quote
Old 09-04-2006, 09:14 PM   #6
passing...
Well, I have decided to pass on this unit after speaking with the seller again. Just too much needs to be done and I don't have that time. I am very handy and fix and build things, plus my Dad builds antique cars, so I am not afraid of a project. But, it is that whole time thing!!!! If anyone sees a reasonably priced trailer, airstream or other, please let me know! Looking for something 2500lbs or less. Again, not afraid of cleaning and cosmetic work, but I need something to start with! I think that is what I wasn't happy about with the other one.....at least if I had cabinets and things to use as a template, I could fix up.
Anyhoo, thanks!
Amanda
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
1964 GlobeTrotter InsideOut 1960 - 1964 Globetrotter 3 09-29-2005 11:56 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 09:41 PM
