Go Back   Airstream Forums > Airstream Community Forums > Global 'streaming > Modifications
Old 05-31-2011, 06:57 PM   #41
"Cloudsplitter"
Originally Posted by zedex View Post
Right now i am trying the unit in the house with trans about 25' away around the corner of the house.Works perfectly. When in the AS the trans was only about 2 feet away and would operate initially but after a while outside trans will not communicate with inside reciever. I am going to forget about the wireless and find a hard wired unit.
Hold the screen door open....wet your finger and put it up.....in the AIR
Old 05-31-2011, 08:12 PM   #42
steel/aluminum fabricator
2004 22' International CCD
Penticton , British Columbia
And then what?
zedex is offline   Reply With Quote
Old 05-31-2011, 08:36 PM   #43
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
And then what?
Not a good question to ask around here. Some people may even post what they are thinking.
On the other hand, I thought you did that to tell which was the wind was blowing—something you don't need a weatherman to tell you.
Gene
Old 11-27-2011, 02:35 PM   #44
Update!!! My wired unit quit working. The sensor worked fine but the digital display decided to not show all the digital pixels. So now i am looking for another wired unit with no success. Who would have thunk it.
Old 11-27-2011, 02:38 PM   #45
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I bought my wired unit at Cabelas in the marine department. The sensor is waterproof and designed to measure water temperatures. Cost was nominal.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 11-27-2011, 03:07 PM   #46
Master of Universe
Gene's Avatar
We bought a new unit last summer after the first one quit. The second one worked fairly well for a while and then started not recording outside temps intermittently. I think it is just Chinese junk. It is getting harder to find quality merchandise.
I could live without knowing the outside temp—I can just stick my head out the door—but when it is cold out it is very useful to know outside temps to make sure the hoses don't freeze and when to run the furnace instead of a ceramic heater.
Gene
Old 11-27-2011, 04:15 PM   #47
"Cloudsplitter"
Thumbs up
KISS.....
You folk's are all to complicated, this sticks on the outside of any window and peals right off when you break camp, got ours at CW several years ago.
Old 11-27-2011, 04:22 PM   #48
Master of Universe
Gene's Avatar
Bob,
Ours has flashing numbers and inside and outside temps (when it works). Doesn't the stick on type in cold months give somewhat warmer temps than outside air because it is on the window within the trailer's heat envelope?
Gene
Old 11-27-2011, 04:25 PM   #49
dznf0g's Avatar
Oswego , Illinois
Originally Posted by ROBERT CROSS
KISS.....
Yeah, but there would be nothing to complain about or debate! Where's the fun in that?
-Rich-
Old 11-27-2011, 04:36 PM   #50
dznf0g's Avatar
Oswego , Illinois
Actually, mine has worked flawlessly. I don't know what brand it is, I picked it up as an impulse buy.....somewhere
-Rich-
Old 11-27-2011, 05:39 PM   #51
billymyers56's Avatar
2020 30' Classic
Commerce , Texas
I have a Oregon Scientific Solar power. It works great.
billymyers56 is offline   Reply With Quote
Old 11-27-2011, 06:12 PM   #52
2000 25' Excella
Northern , California
I use an Oregon Scientific wireless base unit with two remote sensors. One in the fridge, and one in a small bag hanging on the expandable wheel chocks. The wheel well keeps it shaded, and since it’s hanging on the chocks, I’m less likely to forget to put it away. No problems after nearly a dozen years of use, always get readings on all three channels, and it tells me who needs batteries.
Kamiak is offline   Reply With Quote
Old 11-27-2011, 06:18 PM   #53
"Cloudsplitter"
Originally Posted by CrawfordGene View Post
Bob,
Gene
Maybe about $5.12 warmer.
Old 11-27-2011, 06:23 PM   #54
Hmmmm.Well, all i can buy in this town is cheap chinese crap. I am going to have to order something decent. Oregon Scientific sounds promising. Like i said earlier, i used to have a wired unit from La crosse and it was great but you cant buy em anymore. Everything is wireless which involves batteries in both units and half the time wont communicate through the shell. There is no way in hell i am sticking my finger out the door I mean really, i do have pride.
Old 11-27-2011, 06:25 PM   #55
dznf0g's Avatar
Oswego , Illinois
Hmmmm, maybe I was wrong....apparently there is some debate and argument " in that old silk hat"!
-Rich-
Old 11-27-2011, 06:28 PM   #56
dznf0g's Avatar
Oswego , Illinois
I have ZERO issues with my wireless' communication. I've never seen a dropped signal. Still on the same set of batts after 2 seasons. I do take them out during the winter (4.5 months a year)
-Rich-
Old 11-27-2011, 06:29 PM   #57
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I stuck my wireless sensor to the inside of the tinted front window protector with Velcro. It's rare when we're camping that we don't put the window protector up, so the sensor is protected, and is away from the window, and will give a good outside temperature reading. It only has to transmit a few feet through glass to the receiver, which is stuck to the mouse fur near the window with Velcro. That way, if it needed to be moved, I could easily attach it somewhere else. But it's been working fine, and is pretty accurate. I have a second sensor in the refrigerator. It works fine too.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 11-27-2011, 06:33 PM   #58
"Cloudsplitter"
[QUOTE=dznf0g;1076907]I have ZERO issues with my wireless' communication.
Me neither....
"Hmmmm.Well, all i can buy in this town is cheap chinese crap."
Mail order?
Old 11-27-2011, 06:34 PM   #59
dznf0g's Avatar
Oswego , Illinois
Mine is zip tied to the sewer hose PVC carrier under the front of the AS. The receiver is on the overhead cabinet above the credenza. It passes through the underbelly and floor. No problem.
-Rich-
Old 11-27-2011, 06:36 PM   #60
dznf0g's Avatar
Oswego , Illinois
STOP!!!!!!!! You just love pokin' your finger in Sasquatch's eye, don't you?
Edit: that was for Robert
-Rich-
Updates on Wireless back-up cameras? dznf0g Audio, Video & TV 462 01-18-2017 07:12 AM
WBCCI New Constitution LI Pets WBCCI Forum 1165 03-28-2012 10:35 PM
Esmerelda the 1992 Excella 29' LawChick 1990 - 1993 Excella 59 02-15-2012 09:36 PM
Wireless back up video? Gringo Audio, Video & TV 4 05-18-2011 06:03 AM
NorCal : NorCal Spring Rally, Casini Ranch, April 15-17 Big Dee Forum Rallies & Meet Ups 731 04-30-2011 11:23 PM
