Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 06-06-2015, 02:26 PM   #1
Fort Worth , Texas
Running TV from Portable AC/DC Inverter While Boondocking- How Inefficient Is This?
I'm boondocking and wanted to watch some TV.
My TV runs on AC power. So I took my AC/DC converter from my car plugged it in to the RV DC plug and plugged in the TV.
If I want to watch TV while boondocking is this something I should keep doing or does it drain a ton more battery than if I bought a DC TV?
mrpettit is offline   Reply With Quote
Old 06-06-2015, 03:00 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Your 110 volt TV using the car inverter surely uses more of your battery capacity than would a similarly sized 12 volt TV because of the inefficiencies of the inverter process. The loss may not be all that significant in terms of amp hours, however, as the inverter loss is usually in the 10 to 15% range but since your TV does not use all that much power, 10 to 15% of a small amount may not be significant.
I'd be more concerned that your car inverter is likely a modified sine wave inverter and not a pure sine wave inverter (more expensive, of course.) Over time, a modified sine wave inverter could damage sensitive electronics such as your TV.
If you are interested in learning more about modified sine wave vs. pure sine wave inverters, use the "search function" on this site.
Bob Martel
WBCCI# 5766
AnnArborBob is offline   Reply With Quote
Old 06-06-2015, 03:16 PM   #3
1974 Argosy 20
Kooskia , Idaho
Inverters today are quite efficient, in the 85 to 90% range. Televisions have some kind of power supply built in to suit their electrical needs. They do not inherently operate on 12 volts DC, so even those 12 volt units may convert their power system from 12 volts.
Bottom line, there could be some efficiency gain on some Television Sets, but there is no guarantee.
That said, the WFCO sine wave inverter supplied with the Airstream inverter package requires almost 2 amps just to be on, so it is not one of those modern efficient inverters I mentioned in the first paragraph. Many of the small, less than 200 watt modified sine wave inverters you can buy for under $30 are a better bet, as they have a standby loss of under 0.4 amps. They will also operate your television just fine.
To all: don't leave your inverter on when not using it, and don't run it to do things like charging your phone. The standby losses of most pure sine wave inverters are quite substantial. A 2 amp load 24 hours a day is 48 amp hours. One group #24 battery only has a total capacity of about 75 amp hours.
I know that my statement seems contradictory. An inverter running a television is ok, but only if you shut it off when not in use, and it would be best if it were not a large pure sine wave inverter, as most of them have substantial running loss at low loads. The 300 watt Morningstar Pure Sine inverter is one of the few exceptions I have found to that statement. Small modified sine wave inverters are actually better for low load use.
Ask a question, get too much information, I know. Sorry, I just have to be complete.
Old 06-06-2015, 03:20 PM   #4
1974 Argosy 20
Kooskia , Idaho
PS: it is very rare for a television or any modern power supply to be damaged by a modified sine wave inverter. A few drill battery chargers a number of years ago had that problem, but most things have been designed differently for quite some time.
Old 06-07-2015, 08:30 AM   #5
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Why don't you purchase a TV that runs on 12VDC and be done with it? I think I paid $149 for mine with a integeral DVD player and never looked back.
Ahab is offline   Reply With Quote
Old 06-07-2015, 05:26 PM   #6
2015 27' Flying Cloud
Albuquerque , New Mexico
The newer LED tvs are more efficient than older units and should be part of the solution. The solar package on our Airstream gives us a complete charge every day and more than 2 hours of tv usage without issue in the evening. Yes turn off the inverter when not using it!
Nmengineer is offline   Reply With Quote
Old 06-08-2015, 07:46 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
There are 12 volt televisions available. A 12 volt TV would take away the need for the inverter.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is offline   Reply With Quote
Old 06-08-2015, 08:14 AM   #8
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
We run a 22" flat screen TV with Directv satellite, or a DVD player off a 800 watt inverter. We can watch a 3 hour movie from the DVD player and leave the house battery with a safe minimum charge until the next generator charging usually in the morning. Satellite TV watching is limited to just favorite programs.......after all we are CAMPING.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
FreshAir is offline   Reply With Quote
Old 06-08-2015, 01:02 PM   #9
1979 23' Safari
Wayland , New York
Absolutely nothing wrong with what you're doing. As mentioned just unplug it when not using it to keep standby losses from draining the battery. This is what I've done, those 1000w inverters are overkill. I've used one of those small 200 watt portable car inverters and plugged it in on the occasion to watch tv or charge laptop. I use 12v to USB adapter, or USB port on stereo for things like charging phone/ipod etc, more efficient than going from inverter for those.
You may be surprised at how little power a led tv uses. If you can adjust brightness, turn it down for even less.
At home I used a killawatt meter on my 42" tv and was able to tweak it to use about 75w.
HiJoeSilver is offline   Reply With Quote
Generac iX 2000 Watt Portable Inverter Generator Frank&Mike Generators & Solar Power 21 11-06-2014 06:20 PM
Propane usage while boondocking Boondocker LP Gas, Piping, Tanks & Regulators 43 04-01-2008 04:12 PM
Water Pressure drops while boondocking Brad Hunt Fresh Water Systems 3 10-12-2007 11:10 PM
South Keeping Cool While Boondocking rseagle Boondocking 5 03-26-2006 11:09 AM
