Also, you have the 2 year newer sister to my rig. Make sure to check the roof seam for the front cap. Its known for leaking if not maintained. I also found the base to the CB antenna over the passenger seat cracked and leaking. No problems since replaced.
I also removed the old cell phone antenna in center but left the wire in place. Later installed a mobile marine sat antenna for my Sirius radio....works perfect!!
Will be glad to share other tips or answer questions as needed.
Mike
I changed out the 19" tube TV up front and replaced it with a 24" flatscreen with built in DVD. While the space was open I was warned about the excess ductwork that might be found. Ended up removing 7' of plastic duct which greatly increased the airflow from the dash AC.
Mounted the TV on a computer articulating arm then used Velcro strips around the opening to hold it in place while driving.
