Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 01-21-2010, 06:03 AM   #1
1987 34' Limited
1987 34.5' Airstream 345
Tyler , Texas
Water pump
Where can I find the fuses for the 12V system in a 86 345. I have lost power to the switch in the bath for the water pump and the switch in the kitchen has been removed by the po. There is not an inline fuse and I cannot locate any other fuses other than the chassis fuses in the glove bosx.
pjude is offline   Reply With Quote
Old 01-21-2010, 08:38 AM   #2
raveson's Avatar
1989 25' Excella
1989 34.5' Airstream 345
Hobe Sound , Florida
fuse location
In my 89 345 the fuse box location is in the same box that contains the 110v breakers below the kitchen drawer, easy access! They are the same as automotive fuses.
raveson is offline   Reply With Quote
Old 01-21-2010, 10:15 AM   #3
1987 34' Limited
Tyler , Texas
Don'tGot fuses
There is nothing below the kitchen drawer other than the converter...(I even pulled the drawer out of the cabinet)I have or say I have looked behind every possible hidding place with no luck. I know there has to be a fuse block somewhere.Pete
Old 01-29-2010, 12:34 PM   #4
345bill's Avatar
Las Vegas , Nevada
Pete, The converter on my 90 345 is located exactly where yours and raveson's (post # 2) are, and that's also where the fuses are, on mine.
We recently got rid of the univolt and installed an Xantrex converter and this one has the fuses still located there but they are covered by a panel that must be removed to access fuses. This cover is simply held on by a single phillips head screw and it's just to the right of the breakers.
Just a guess but maybe yours is similar.
345bill is offline   Reply With Quote
Old 01-29-2010, 03:49 PM   #5
Chuckles's Avatar
Iwerne Minster , Dorset. UK
We had a 345 in last year for UK Preparation and 12/120/230 volt upgrades. All the 12volt circuits were protected by Circuit Breakers, in a panel below the drawers or in the bottom of the two door cupboard under the sink unit, not fuses. Never found a single fuse!
It may be the CB's are playing up. Sorry I can't tell you which is which as the client has taken the 345 on now, but a simple continuity test across the breakers should show up an open circuit.
Either find the positive then check for 12volts after each breaker or test with continuity lamp/meter across the terminals.
CB's are small "blocks" about 3/4" x 1/2" x 1/8" very approximately (doing this from memory you understand!) You will see them all fixed to "bus-bars" - no wires.
Hope this helps.
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 02-01-2010, 04:14 PM   #6
Chuckles's Avatar
I have some pictures now but cannot get them out of Outlook onto the forums, so I have tried the PDF approach - let me know if it works!
The pics show the compartment under the oven/cupboard where oven would have been, and a brown metal panel door. The breakers are behind this door. The next picture shows two rows of breakers all joined by a BUS-BAR with a single heavy cable on that. The other side of the breakers are terminals with single wires going to their relevant circuits. on the door is the circuit diagram showing which fuse goes to which.
Hope this helps
Chuck
Dorset UK
Old 02-01-2010, 05:53 PM   #7
345bill's Avatar
Las Vegas , Nevada
Chuck- pic's came through great.
Old 02-02-2010, 04:33 PM   #8
1987 34' Limited
Tyler , Texas
water pump fuse search
Hi! Thanks for the pic's but the panel is labeled 120V and not 12V as I need. Also are these breakers resetable? or must they be replaced?
Pete
Old 02-02-2010, 10:03 PM   #9
Chuckles's Avatar
Pete,
If they are open circuit replace them. Generally they reset after a while if there is a cause for them to blow. There are no moving parts or buttons!
Chuck
Dorset UK
Old 03-02-2010, 04:58 PM   #10
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
If your circuit breakers are OEM, they are thermally operated ... get hot and open ("break"), cool off and close (circuit works again). You can make this happen with an ice cube and a heat source, to check each pone for operation. AS paint stripper heat gun works fine. Good luck.
Jamie
jking is offline   Reply With Quote
Water Pump Vomits water out of faucets! thoreaulycra Water Heaters, Filters & Pumps 5 12-19-2008 11:12 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Water Pump running, water is not... CampSayler Water Heaters, Filters & Pumps 4 09-23-2004 04:34 PM
