Old 05-01-2011, 08:07 PM   #1
1988 34.5' Airstream 345
Cookeville , Tennessee
Radio Only Works With Ground Power
I'm new to Airstreaming and just bought a 1988 345. My am/fm car radio seems to be hooked up so that it only works when I'm plugged up to the outside ground outlets. Won't work running down the road. How should it be wired up. I thought it would trigger off of the ignition switch just like every other vehicle I've ever owned. If it should, then does that also mean that it shouldn't work at all without the key on, like while camping.
Any thoughts?
robersonwill is offline   Reply With Quote
Old 05-02-2011, 07:54 PM   #2
1989 34' Limited
southern , ontario
Find a wire that has power at all times, you may have selected a feed (hot wire) that is de-energized when the ignition switch is turned on, or if you power the radio when the ignition switch is in accessory mode.
letsgo is offline   Reply With Quote
Old 05-02-2011, 09:06 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Isn't this the same set of symptoms as your lights? (http://www.airforums.com/forums/f311...tml#post987384)
Vaughan
vswingfield is offline   Reply With Quote
Old 05-03-2011, 01:41 AM   #4
1989 34.5' Airstream 345
Silverton , Colorado
Our radio comes on when I disconnect the batteries, then reconnect...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 05-03-2011, 04:24 AM   #5
I know they wire the radio into the coach batteries instead of the ignition so if the kill switch for the coach batteries is in the off position the radio will not have power while driving and it explains why it works when plugged in, then it's running off the coach's 12 volt convertor. They do it that way so you can play the stereo while camping and not have to have the ignition turned on. That could be the issue with yours...
8rmesse is offline   Reply With Quote
Clipper, Land Yacht, Radio TV Speakers masseyfarm Audio, Video & TV 2 06-23-2013 10:49 PM
Stumped by power steering dadstoy Mechanics Corner - Engines, Transmission & More... 14 05-30-2011 01:57 AM
'62 safari shore power mmenchel Batteries, Univolts, Converters & Inverters 4 04-21-2011 07:17 AM
Solar Power Quandary for my '58 mello mike Generators & Solar Power 7 04-06-2011 08:05 PM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
