Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 03-01-2015, 10:24 AM   #1
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Plugging in to a normal house outlet?
Am I missing something? Is there a way to hook to a house current plug to power some minimal coach functions? Battery charger, fridge etc.
I have a couple of situations that I encounter occasionally at friends places where there is access to an outside plug. But no RV style 30 amp outlet.
Is there an exceptable way to plug the coach into this sort of outlet safely?
Thanks Richard
tevake is offline   Reply With Quote
Old 03-01-2015, 10:40 AM   #2
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Thanks Richard
Here you go the basic RV adapter
Park Power, Adapter, 15M/30F, Round, Bulk
Here is a full slate of adapters
http://tweetys.com/rv-electrical-adapters.aspx
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 03-01-2015, 10:40 AM   #3
dstalzer's Avatar
2005 25' Classic
You need a RV 30 amp to 15 amp adapter that is sold at Camping World and at most RV dealers. This setup will plug into a standard 15 amp home outlet. It will not run your AC or electric water heater, but will do the minimum that your asked for. I did this for many years before installing a 30 amp RV outlet connected directly to my circuit box in my garage.
Dennis
dstalzer is offline   Reply With Quote
Old 03-01-2015, 10:50 AM   #4
1974 Argosy 20
Kooskia , Idaho
The adaptor is also available at places like Wal Mart.
Old 03-01-2015, 10:59 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
With an adapter, you will be able to easily plug into a 15 or 20 amp, preferably the latter. You will be able to run most everything electrical in you unit but the air conditioner or heat pump. Everything else should work fine.
If you have an electric water heater, I would turn it off when using a microwave, coffee maker, or toaster.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 03-01-2015, 12:05 PM   #6
Thanks all for the quick and helpfull reply.
I'm off to go find one of those adapters now. :-)
Cheers Richard
Old 03-02-2015, 11:19 AM   #7
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Since I did all my own wiring around the farm,, my 110 outlet on my car shed is wired super heavy with an industrial rated outlet. I can but I dont could pull a full rated load with AC from it. But there are limits to what the adapter plug able to handle it safely. Just use common sense and your ok..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Plugging in At Home henw Electrical - Systems, Generators, Batteries & Solar 65 11-30-2015 10:28 AM
Plugging in to a house gcasson Full-Timing, Winter Living & Workamping 53 01-19-2015 11:49 AM
Plugging holes on the A frame Tino643 General Repair Forum 2 04-10-2013 07:37 PM
Blowing Fuses When Plugging Into Shore Power 1hank1 Electrical - Systems, Generators, Batteries & Solar 1 04-24-2012 08:29 PM
Lights quit working after plugging cell phone charger into cigarette lighter hagnik Lights - Interior & Exterior 6 06-20-2011 09:57 AM
