08-08-2010, 09:28 PM
1984 31' Airstream310
College Station
Occasional no start!
Every once in a while after it has been running the 84 310 454 will not start. I wait a few minutes and then, it will start. It has a new starter and new solenoid. I was told to have a mechanic enlarge the coil inside the starter!
Anyone had a similar experience?
PD
08-08-2010, 09:53 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
Ricky
08-09-2010, 10:45 AM
1989 34.5' Airstream 345
Silverton
Because the starter is located close to the exhaust manifold, some reports of no-start after running have surfaced...if you let it cool off awhile, it will start again...we have had this problem, so when I shut off the engine after a drive, it's because I don't plan on going anywhere for awhile...otherwise(on the road from A to B), I will leave it running.
Seems to me there is reference in a thread to installing a heat shield...mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
08-09-2010, 01:47 PM
Las Vegas
, Nevada
[QUOTE=pdallas;880950]Every once in a while after it has been running the 84 310 454 will not start. I wait a few minutes and then, it will start. It has a new starter and new solenoid.
pd- Let's narrow this down. When it's not starting does it turn over at normal RPM'S or not at all? Just clicks? Turns over slow?
08-09-2010, 02:15 PM
Tramp Streamer
1995 28' Excella
Artist
, at Large
Hello PD,
Scrapy is spot-on!
I had the same issue with my old 454 P30 chassis MOHO.
I installed a shield and a insulating blanket over the starter and I never had the problem again.
Hi Scrappy!
Swishes,
08-09-2010, 04:24 PM
1968 24' Tradewind
Oxford,
, Mississippi
The heat from the manifold and block "heat sinks" the starter and that causes an increase in internal resistance and a no start. ArtStream's fix is has been used with success for years in Burb's and trucks with the big block. I have never read why the big block was more prone to the problem but is was.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
08-09-2010, 08:27 PM
College Station
Thanks Guys!
345bill. The motor will do nothing! Plenty of juice to dash lights, but when switch is turned; nothing. Definitely acts like the heat sink thing! It already has a shield. I can buy some thermal wrap and wrap the overall unit easy enough!
Thanks for the help!
PD
08-09-2010, 08:37 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
do the lights dim when you turn the key?
Ricky
08-09-2010, 09:01 PM
College Station
The dash lights stay bright. I have not had anyone eyeball the headlights.
PD
08-09-2010, 09:31 PM
Silverton
PD,
The starter won't do anything, if it's the heat thing...turn the key, and you get...well...
n o t h i n g...
Mr Artstream...long time, no see...good to hear from you, my friend...Q in Nov...
mike
Michael & Tracy
1989 345 Motorhome
08-10-2010, 12:40 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
ok, it sounds like the started solenoid is not being activated. the first things i'd try are:
1) chock the wheels, wiggle the shifter while in neutral and see if the starter comes to life.
2) test the ignition switch and see if it is sending 12v to the starter.
Ricky
08-11-2010, 08:18 AM
Las Vegas
, Nevada
pd-As everyone has already said about excessive heat in area of starter be sure to check condition of all starter wires at starter. That's also where the heat sink is, on my 345.
Everything Ricky said in post # 11 is what I'd check also. Although a faulty neutral switch shouldn't be heat related it could very well be a vibration problem causing intermittent no crank.
You mentioned in post # 1 that it has a new starter and solenoid. Did you have the same problem before these were installed?
Let us know.
08-11-2010, 09:25 AM
Las Vegas
, Nevada
pd- I just remembered one problem I had on my 345 that's similar. Where the neg battery cable, from start battery, connects to the frame had a loose/crummy connection that caused cranking & battery charge problems, intermittenly. Lights, radio and stuff would work fine. After I cleaned the cable end, new bolt & nut, the problem was cured. Easy enough to check.
08-11-2010, 06:12 PM
College Station
Thanks Bill: That would be a good thing to do anytime!
08-28-2010, 09:17 PM
College Station
We live and learn! After cleaning up wire terminals, defecting out the rebuilt starter, insulating starter unit, I made a discovery! On this 84 310, there is an additional solenoid mounted to a bracket just in front of the air cleaner. After messing around with a tester probe, I discovered the lead to the starter was pretty rusted and actually was keeping the test light from shining brightly. After scratching the rust slightly, I got a brighter light and WALA the fool engine started. Replaced the solenoid with a matching napa part and have now been start happy for 20 tests. It may be my imagination, but I think I am getting a higher amp reading as well??
Hope this helps somebody else down the road.
PD
08-29-2010, 08:11 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
you'll be able to deliver more amps to the starter. it sounds a lot like the thread i listed in post number two ;-) i learn a lot on this forum :-)
on a side note... i had two bad solenoids from napa (with the posts on the side) i swithed to the type with the front type terminals ith good results. the other type would frequetly not release without tapping on the solenoid.
Ricky
