Leaking forward running lights
I'm chasing leaks in the overhead of the cab on my 345. Pretty sure its coming from the running lights above the windshield, down the A pillars and to the floors.
In looking at those lights, there is a fairing base then the light fixture its self.
I know that many here have replaced their lights up there. What do you find of the fairing? Have you removed them and resealed under them? Just caulked around them?
What is a good replacement LED light fixture?
Have you found that the fairing is leaking into the cab? I do see a weep hole at the bottom of the fairing and those seem to be plugged up. Could that be my problem, just not draining? The fitment of the light does not look all that water tight.
Thanks for any help in getting me up to speed on getting these sealed up and drawing less current.
Cheers Richard
