Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 07-29-2014, 11:11 AM   #1
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
Dashboard AC question
OK folks, I've been struggling with a 134 conversion of my Dash AC, and have the following question for anyone who has a working dash AC:
My clutch pulley has 2 belt grooves, should there be 2 belts or just one? Thanks!
gaiaenviro is offline   Reply With Quote
Old 07-30-2014, 09:24 AM   #2
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
I converted my 91 350 LE to 134 and I have 2 groves but only 1 belt. Click image for larger version
Name:	ImageUploadedByAirstream Forums1406733853.322895.jpg
t7389sg is offline   Reply With Quote
Old 07-30-2014, 09:35 AM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
Jay , Oklahoma
I am in the middle of this process.
My '91 350 LE has two groves and one belt.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 07-31-2014, 11:26 AM   #4
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
My 91 300le dash AC is not working, and the compressor is making a nasty sound. Has anyone done a DIY on the conversion?
SebasSF is offline   Reply With Quote
Old 08-07-2014, 07:38 PM   #5
1986 34.5' Airstream 345
Pittsville , Maryland
I have told that you can drop in 134 without doing any changes just dump the 12 and pull vac . The best way is fix problems with old system and find some 12 it works a whole better than 134 . I know you don't believe me so call National Refrig the people who make 134 and ask them .
Ice Berg is offline   Reply With Quote
Old 08-07-2014, 08:03 PM   #6
gaiaenviro's Avatar
I like the idea, read an article with similar concepts (5 yrs life with a 12/134 mix). My problem (and I have 2 cans of 12) is that I can't get the system to work at all with 134, so don't want to waste the 12....
Old 08-07-2014, 10:31 PM   #7
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Your system is pretty simple in that it pressurizes refrigerant, reduces the pressure and removes heat. In doing this the refrigerant changes from a gas to liquid and back and fans remove heat inside the coach and other fans remove more heat in front of your radiator. Some refrigerants are more efficient than others but that is another very long discussion.
If you take the air hose from your compressor and blow air toward your hand it feels cool. This is the same rapid reduction in pressure in it's simplest form.
You need to get a 134a manifold gauge set (because you have 134a in the system) and check the system to see if you are making pressure on the high side and reducing pressure on the low side. If not then you can troubleshoot the system to find the problem.
Cheers, Dan
~ Margaret Thatcher ~
Dashboard Repair of Vinyl Leather silvertent General Motorhome Topics 3 06-08-2006 06:06 PM
Dashboard Repair on Vinyl Upholstery silvertent Upholstery, Blinds, Walls & Interior Finishes 2 06-01-2006 11:53 AM
Dashboard Makeover Chaplain Kent Classic Motorhomes 32 03-30-2006 05:34 AM
To Paint or Not to Paint My Dashboard Chaplain Kent General Interior Topics 8 02-23-2006 07:41 AM
Instrumentation/Dashboard redo thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 06-03-2002 09:02 AM
