Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 2005 and newer - Bambi all models
Old 05-06-2014, 07:52 AM   #41
GP1152's Avatar
2015 23' International
Sacramento , California
A spot at Shasta Lake that, according to the map, should be under water. (Water levels are really low)
GP1152 is offline   Reply With Quote
Old 05-06-2014, 09:25 PM   #42
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
toaster
Originally Posted by idroba View Post
If you have a 2014 the standard inverter option is now a 1000 watt sine wave inverter. (About a $700 extra). I have found a regular small 120 volt toaster, rated in the range of 800 to 900 watts, works fine on mine. Just look on the bottom for the watt rating, virtually all of them state it.
The inverter will draw about 90 amps when making toast, but for a brief period. Lets say it is 3 minutes. That is 1/20 of an hour, and at 90 amps / 20 = 4.5 amp hours for toast. If you have two 75 amp hour batteries each, that is not a very serious energy demand. On a solar recharge, depending on the panel size, half hour to an hour to put it back.
I like "real" toast from an electric toaster....lol.
Thanks Iroba for the toaster info. Unfortunately my FC is 2013, and the inverter is 750 watts...and my regular toaster does not work on the inverter. Oh well, another future upgrade project....maybe.
RAH is offline   Reply With Quote
Old 05-07-2014, 12:24 PM   #43
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
GP1152
Thanks for posting the great boondocking ideas. Maybe you could also put them in the boondocking section, so they will be seen by more folks and more folks can learn and use your ideas.
Dan
Seattle to Alaska, could use a few tips and advice. BusDriver On The Road... 182 11-25-2015 03:18 PM
Hi from AZ-almost a trailer, almost an AS jforb Member Introductions 10 01-31-2011 12:02 PM
Temp/Air bags...few other questions.. swinginping Classic Motorhomes 4 02-15-2008 09:10 PM
almost....almost.... rama777 Electrical - Systems, Generators, Batteries & Solar 30 11-04-2006 10:18 AM
Our first trip! Pls recommend dry run camp and other info... sarmimi On The Road... 30 04-11-2005 06:02 PM
