Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 06-13-2012, 12:27 PM   #21
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Dznf0g
That is not what I would have expected. Your experience changes my thinking on replacing as a preventative item. My thought was that the internal diaphragm was the weak point, and it simply fail to provide gas flow upon failure.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 06-02-2013, 10:54 PM   #22
1970 25' Tradewind
Harrison Hot Springs , British Columbia
I have a 1970 trade wind with the original regulator. All appliances work fine with now the exception of the cat heater, hot is no longer hot. Is it time for a new regulator, or shall I tinker with the old one. I have read that the new ones are of poor quality and need frequent replacement. Perhaps I should inspect the diaphram and spring!!!
Any thoughts?
Ribbler is offline   Reply With Quote
Old 06-02-2013, 11:14 PM   #23
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
If your lines are exposed to the sun you could get electrical flume and put in on your hoses. I have done that on my boat for my BBQ.
TinCan
graysailor is offline   Reply With Quote
Old 06-03-2013, 12:19 AM   #24
Pileus's Avatar
1985 31' Excella
Seguin , Texas
Ah, the kicker: that 48 year old regulator was made in the USA. The junk out there now is made in China...
Pileus is offline   Reply With Quote
Old 06-03-2013, 07:06 AM   #25
dznf0g's Avatar
Oswego , Illinois
Originally Posted by tlavergne View Post
I don't worry about the regulator
as much as the pigtail rubber gas lines between tanks and regulator. There is lots of opportunity for leaks there over time.
Yup, My OEM lines were only 6 years old and were rock hard and stiff. Seeping at the crimps, so replaced this spring.
-Rich-
Old 06-03-2013, 07:34 AM   #26
1981 31' Excella II
New Market , Alabama
The rubber hose was at fault on my trailer but I replaced the regulator anyway. This was the low pressure side hose and it was swollen shut from oil exposure. I think I will replace it with stainless tubing at some point which won't crack from vibrations like copper will.
Perry
Old 06-03-2013, 09:15 AM   #27
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Hoses on our 1999 were inflexible. When I removed lowest point connection some foul smelling liquid poured out! It smelled like the odor chemical used in producing the classic smell to the gas. It was like a mixture of deteriorated fuel line slime typical in vehicles.
Being curious, I cut open the rubber lines. I found some bubbled interior which means the lines were indeed failing from inside too. Clearly the originals were a threat.
With constant exposure to the elements and marginal quality in "new" parts, the actions are simple, a mere nuisance and recommended if not necessary.
I replaced the rubber lines, regulator and tank connections.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-03-2013, 09:27 AM   #28
1981 31' Excella II
Just about all compressors use oil and contaminate the propane with oil which finds its way into the rubber lines and caused them to swell. The oil absorbs the smell from the gas but the oil is not the source of the smell.
Perry
Old 06-03-2013, 11:19 AM   #29
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Perry
Thanks Perry!
Channing
WBCCI# 30676
Old 06-03-2013, 01:10 PM   #30
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Regulator Replacement
Not sure it should be a scheduled replacement part. But you can get the entire set of hoses, regulator and crossover valve for around $110 from Inland Andy or any other supplier. Not a bad price for peace of mind.
fltlevel510 is offline   Reply With Quote
Old 06-03-2013, 02:25 PM   #31
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I recently bought all three hoses and new 2-stage auto regulater for under $60 including Prime shipping from Amazon.
MICHAEL
Old 06-03-2013, 04:52 PM   #32
Possible leak?
I have a 1990 -- all original regulators and hoses. My open tank sat for over a year and one time I thought I smelled the propane. I haven't soap tested it yet, but saw this thread and knew I needed to read it.
Just finishing a water leak at the city water inlet with a leak in the grey PB water connections. In fact just received the parts from Amazon today for the repair. But that is another problem....
AWChief: you just posted that you ordered some parts off Amazon, what exactly did you get. Probably most of our coaches use about the same thing. I have two aluminum 30 gal tanks. Would appreciate some part suggestions.
And how far back did you feel you needed to replace? Maybe the hose degradation could be similar to the ethanol fuel problem many see with older outboard boats that sit for a while.
thanks for your input
Sav'h Steve is offline   Reply With Quote
Old 06-04-2013, 06:34 AM   #33
AWCHIEF's Avatar
Images: 33
Steve: I bought,
Camco 59005 RV Propane Double-Stage Auto-Changeover Regulator ($30.55)
2-Camco 59053 12" RV Pig Tail Propane Hose Connector ($11.32 @)
I had the other hose made up by a local gas supplier for under $10.00. I believe it is about 38 inches long. It goes from where the copper line comes out from under the trailer to the regulator.
MICHAEL
Old 06-04-2013, 11:15 PM   #34
TinCan
graysailor's Avatar
2016 30' Classic
When it comes to propane, gasoline or any highly flammable liquid safety exceeds saving money.
TinCan
Old 06-06-2013, 06:03 AM   #35
AWCHIEF's Avatar
Images: 33
And cost is not necessarily an indication of quality.
MICHAEL
Old 06-06-2013, 04:50 PM   #36
Vintage Kin
Fort Worth , Texas
http://www.airforums.com/forums/f287...tor-23016.html
Old 06-07-2013, 07:54 AM   #37
Pileus's Avatar
1985 31' Excella
Seguin , Texas
Avion used these:
Fisher Controls Automatic Changeover Regulator - Dultmeier Sales
Cost is about $250 each, but high quality.
Old 04-24-2015, 07:43 PM   #38
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Replacement for Marshall Gas pigtail Model A4
Rich, what did you buy to replace your propane pigtails (and where)?
My OEM 12" pigtails were made by Marshall Gas Controls 8 years ago and one now has a small leak. So I want to replace both pigtails.
Did you need to buy an adapter for the fitting into the regulator? (Something about metric vs. inches.)
Did you use yellow gas line thread seal tape on the connection to regulator?
Of course, anyone else is also welcome to share their experiences in finding the correct replacement propane pigtail.
Thanks!
SilverGate is offline   Reply With Quote
Old 04-24-2015, 08:17 PM   #39
dznf0g's Avatar
Oswego , Illinois
Silvergate,
I don't recall where I got them.....I want to say Camco from Camping World, but I'm not sure. Yes and adapter was required, and yes I used yellow thread tape.
-Rich-
Old 04-25-2015, 09:21 AM   #40
SilverGate's Avatar
2007 23' Safari SE
Silvergate,
Thanks, Rich!
Bill
