Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-28-2014, 07:02 PM   #1
1968 30' Sovereign
New Richmond , Wisconsin
Replacing black water tank with grey water tank
We're new at this and can definitely use some advice! We are in the process of pulling everything out of the rear washroom in our "new" 1968 Sovereign because of bad rot under the rear window. We will be replacing the floor as well as replacing and adding some of the cross bar supports. We have come to the decision that we will be using a composting toilet (Nature's Head? SunMar Mobile?) instead of the standard toilet that was there. We have used a composting toilet in a Northwoods cabin for the last 11 years with no odors and no problems.
Therefore, we have also decided to replace the original black water tank with a grey water tank which will also give us some additional boondocking options. I would imagine others have done this, but we need some advice as to what and how.
The original BW tank measured approx 49.75"x24" on the wide end x 5.5" tall on the deep end. The galvanized box it sat in measures 51"x24.5"x7.5" deep. There were 1/2" styrofoam sheets on all sides - except the top - of the BW tank when it was in this galvanized box.
If we do not plan to winter camp, do we need to put styrofoam sheets or insulate the grey water tank on all sides? Could we actually get a larger grey water tank to fill the dimensions of the galvanized box (which we are also replacing)? Does anyone have any suggestions for a source for the grey water tank at a reasonable price?
Any suggestions or comments would be greatly appreciated!
Thank you!
ID:	220115   Click image for larger version
ID:	220117   Click image for larger version
cheetah1 is offline   Reply With Quote
Old 08-28-2014, 07:32 PM   #2
Thank you!
A black water tank should never be discarded so that a gray water tank can be used.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-29-2014, 04:49 AM   #3
Tincampers's Avatar
Sneedville , Tennessee
Why not? It makes good sense to have more gray water storage.
Tincampers is offline   Reply With Quote
Old 08-29-2014, 06:07 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
To OP, you were not clear on one important point, what are you planning to do for your black water? Drive to the nearest gas station to use their facilities?
Bob Martel
WBCCI# 5766
Old 08-29-2014, 06:27 AM   #5
1968 30' Sovereign
Our reason to replace the black water tank with a grey water tank is that we are refinishing the bathroom with a composting toilet. Doing that, the only waste water we will have is grey water. Since the 1968 Sovereign did not originally come with a grey water tank, we are thinking replacing the BW tank with a grey water tank as we are replacing the floor makes sense at this time.
Andy, is there a reason you have for the "black water tank should never be discarded so that a gray water tank can be used" reply given our intent here? Are we missing something?
Old 08-29-2014, 06:27 AM   #6
1968 30' Sovereign
Andy, is there a reason you have for the "black water tank should never be discarded so that a gray water tank can be used" reply given our intent here of using a composting toilet? Are we missing something?
Old 08-29-2014, 06:36 AM   #7
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Yes, why not? He's said that he's installing a COMPOSTING toilet.
That maybe limits his resale to people who are interested in such but many people are not interested in resale. They are interested in having their trailer do what they want it to do for them now.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 08-29-2014, 07:19 AM   #8
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
The styrofoam in the metal box served two purposes:
Provided insulation to help keep the black tan from freezing.
Provided a sloped floor for the black tank to sit on inside the flat bottomed metal box.
When I built our tanks out of ABS, I enlarged the black tank to completely fill the metal box, but kept the sloped floor for drainage. I used new Styrofoam to create a new sloped floor for the tank to sit on, but no foam around the side. I also eliminated the heat tube from the furnace into the tank box as we never go cold weather camping.
If we ever decide to do cold weather camping in the future, we'll invest in heat mats for all 3 tanks.
For our gray tanks, I built them with a flat bottom and a bottom drain.
For your gray tank, if you want to keep the drain on the side where the current black tank drain is, then I think you should keep a slight slope to the bottom of the tank so it drains better. If you can do a bottom drain, I don't think the slope to the bottom of the tank is as important. Ours drain just fine.
You can find places on the web that will custom build a tank. Several folks in the forums have had that done. They tend to be pricy though.
Do a web search for RV Holding Tanks and you'll find a bunch of places that sell various sizes of tanks. Maybe you can find one the right size for your needs.
Old 08-29-2014, 08:40 AM   #9
Sorry, but I do not understand how black water can be converted to gray water.
Bacteria, a plenty.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-29-2014, 09:42 AM   #10
wxbuoy's Avatar
Wildwood , Florida
Send a message via Skype™ to wxbuoy
Bacteria, a plenty.
Andy,
Composting toilets separate the urine from the solids. Solids go down into a chamber with peat moss or coconut husks. Urine is collected in the front in a plastic removable container that you can take to a bathroom and dump or if out boondocking dispose of where you might pee outside.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 08-29-2014, 04:00 PM   #11
Chelsea , Michigan
Images: 12
Cheeta1, I think that a lot of us missed the all important detail in your original post regarding your conversion to a composting toilet and that may have tainted many of the responses you received. With that clarification, your idea to remove the existing holding tank entirely and replacing it with a brand new tank to be used solely for grey water is sound. Good luck!
Bob Martel
WBCCI# 5766
Old 08-29-2014, 04:35 PM   #12
Mantua , Ohio
Why not just route the gray water into the black tank and block the black water inlet from where the toilet was. Jim
Old 08-29-2014, 04:39 PM   #13
1972 27' Overlander
Denver , North Carolina
Andy,
Shes gonna REPLACE the black tank with a new Gray tank. And a composting toilet, All in all a good option.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 08-29-2014, 06:37 PM   #14
1968 30' Sovereign
Sergei, you are right on in your statement. Having used a composting toilet in a small cabin up in northern Wisconsin for the last 10+ years, we know they work well and work without odor. That experience is what is making us confident in doing this in an Airstream also. We've read one too many horror stories about a leaky black tank, etc while on the road!
Old 08-29-2014, 06:42 PM   #15
1968 30' Sovereign
Andy, I should have been more clear on what we were doing. Dave & Felicia are right on when they describe the workings of a composting toilet. There is a second model we are also considering that has both the solids and the liquids go into one drum where the liquids are evaporated and all else is composted. We use that system in our cabin in northern Wisconsin and it is a SunMar composting toilet. We're considering either the Nature's Head or the SunMar RV composting toilets for our application. What's in either toilet NEVER enters the grey water tank.
Old 08-29-2014, 06:44 PM   #16
1968 30' Sovereign
Bob, I think you right and I'm sorry I did not make that more clear in the original post! Thank you for pointing that out!
Chester
Old 08-29-2014, 06:47 PM   #17
1968 30' Sovereign
Minno, thank you for this information! I guessed the styrofoam was there for insulation, but it was so badly deteriorated on the bottom - I did not pick up on the slope function of the styrofoam. That is good to know and with living in northern WI, I want to make sure as much water gets out as possible before those "balmy" -20 temps hit in the winter!
Old 08-29-2014, 06:51 PM   #18
1968 30' Sovereign
Jim, I would love to do this to save some $$$, but the BW tank we pulled out had a crack along the bottom and also had serious separation where the dump valve meets the body. Since we are in the position of replacing the floor there and have to drop the belly pan in that area anyway to weld some cross braces and brackets in place, we figured this was also the time to replace that BW tank.
Old 08-29-2014, 06:57 PM   #19
1968 30' Sovereign
Thank you to everyone for your responses! Has anyone ever replaced a tank in the back washroom (under the floor) and come up with a way to then access and be able to "service that tank" by dropping the belly pan in that area rather than having to pull the floor up if something goes wrong?
Old 08-29-2014, 07:09 PM   #20
1976 Argosy 24
Chester,
Maybe somebody has but I didn't and you SHOULD.
Sergei
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
VTS Vintage Grey Tank for Black Tank? bluemoontwo Waste Systems, Tanks & Totes 1 11-27-2012 08:03 AM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 06:47 PM
Grey/Black Water Tank Capacities BeBop Waste Systems, Tanks & Totes 3 06-18-2004 07:15 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
