Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 06-13-2005, 06:22 AM   #1
1962 19' Globetrotter
2001 31' Excella
LP Regulator
I have the original Fischer LP regulator on my coach. Seems to work great. However, when there is a large demand for LP (when the water heater fires up), if you are up close to the regulator it sounds as if there is a leak. There's no leak though. Is it normal when there is a large demand for LP to hear the regulator?
Craig is offline   Reply With Quote
Old 06-13-2005, 07:03 AM   #2
Retired.
. , At Large
I have heard this hissing, whining sound also. It is the low pressure LP being sucked out of the regulator. Some regulators do this, most don't. If you want to be sure, run the coach by a RV specialist, and have them take a listen. They may, but probably not, charge you a couple of bucks, but it will be worth it in peace of mind.
Old 06-13-2005, 07:13 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I used to have a regulator on my SOB that had a low moan sound dependent upon the gas flow. Never caused a problem, just a little concern the first time you hear it. The big regulator on my home natural gas supply moans (only louder) when the water heater is running. I always thought it was the metering mechanism until the TT regulator started doing its song.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
LP Regulator PatCrusse LP Gas, Piping, Tanks & Regulators 27 05-15-2004 01:22 AM
Marshall 250 regulator failure nickcrowhurst LP Gas, Piping, Tanks & Regulators 11 04-18-2004 07:08 AM
Fix or replace LPG regulator? Roundhead LP Gas, Piping, Tanks & Regulators 26 03-27-2004 03:28 AM
Grand Hall Ent. gas regulator recall 53flyingcloud LP Gas, Piping, Tanks & Regulators 0 12-23-2002 07:29 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
