07-07-2016, 06:36 PM
2005 25' Classic
New Braunfels
Dometic Refrigerator Flame Going Out on Highway
When traveling on the Interstate at or near 70 miles per hour, our refrigerator is shutting off while running on propane. We noticed this when we kept seeing the 'Check' light illuminate after traveling on Interstate 40. On slower back roads and while camping we aren't having any issues. I've removed the burner windshield, cleaned the burner/orifice area, and reinstalled the windshield, but we keep having this issue. Any thoughts on what else I should check or anything I can do do better protect the flame? I think after 30 seconds of trying to relight, the refrigerator stops and illuminates the 'Check' light. Is that correct?
Corey
Turnerstream.com
07-07-2016, 06:59 PM
1974 25' Tradewind
Calgary
, Alberta
I know this is going to foment a flood of indignant replies that "We never shut off our propane and it's okay!" but I think you'll find that if you look at any trailer towing publications anywhere, they will all tell you to shut off your propane tanks at the tank valve while traveling.
For instance:
Manitoba Insurance pamphlet (page 8)
BC Things you need to know
Just sayin'. I'm sure that you could find a recommendation from every state and province's DMV, to shut off the propane while traveling.
The fact is that if your fridge is worthy of the name, and you have it and the freezer reasonably stocked with food items and beverages, it will keep itself cool enough through a day of towing that there is no problem shutting the thing off while on the move.
Edit:
According to this link, it's illegal to travel with the propane (tank) valves open. That means you would be charged and possibly be found negligent if any problem were to occur due to the valves being open while you're going down the road. Any lawyer for a third-party injury or property damage claimant would definitely have a field day.
07-07-2016, 11:43 PM
2008 27' Safari FB SE
Miami
Don't know where the author of the article you linked to got her information but it is perfectly legal, at least in Florida, to travel with the propane on and the refrigerator operating on it. I know of no U.S. Jurisdiction that prohibits the practice other than a handful of vehicle tunnels (I.e. The Chesapeake Bay Bridge-Tunnel).
Most of us do it. But everyone is free to make their own decision.
I suspect that towing at 70 has a lot to do with the reefer flame blowing out. You may need to extend the baffling or add a screen behind the door louvers.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
07-08-2016, 07:13 AM
1974 Argosy 26
Morrill
, Nebraska
Why even have a refer if you shut it down while traveling? You might as well have an ice box.
2007 30' Classic S/O
Somewhere
, South Carolina
Not sure if your unit was part of the recall to add extra shroud. Search for your fridge.
07-08-2016, 07:25 AM
2008 25' Classic
Full Time
I had the same problem on my preowned 2008 Classic 25fb when I purchased in 2013. I had the recall performed which added a larger shroud around the burner unit. Luckily this fixed the issue.
Kelvin
07-08-2016, 11:42 AM
2000 19' Bambi
mt. Prospect
I had this problem for a couple of years- I'd stop while on the road, and half of the time find the propane flame had gone out. Problematic, at the least, if you want to keep things in the fridge from warming up. Tried all of the suggestions - cleaned the burner assembly and chimney, put a wind blocking layer of furnace filter material inside the exterior fridge door, etc. I started thinking about replacing the thermocouple, and while examining what would be involved, I found that the connection in the thermocouple line (it's inside the exterior fridge door) had come loose - it was finger tight, and a bump would probably cause a loss of voltage and shut down the gas flow. Tightening with wrenches fixed that problem - it's been a couple of years with no further problems.
No WD, but a great DW!
07-08-2016, 12:37 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
X
X2
Here is what the recall shroud looks like on our fridge.
07-08-2016, 12:46 PM
2009 28' International
Pacific Palisades
Kelvin
Anybody have a link to this specific recall? I can only find the link for older models for the unit working on electric, and nothing for a larger baffle recall.
Thanks!
07-08-2016, 12:58 PM
1974 25' Tradewind
Calgary
, Alberta
I did some more reading and I may stand (sit) corrected, at least partially. I did find out some interesting stuff. - Nova Scotia, Manitoba, and New Jersey prohibit travel with open propane cylinders
- At least one state (Virginia?) has a maximum of 2, 20 pound tanks
- Ferry services definitely prohibit open propane cylinders.
We've always traveled with closed propane tanks; we pre-cool the fridge before leaving on a trip and we haven't had any issues with food warming up during a day's travel. As noted, you're free to do what you like...
07-08-2016, 04:52 PM
Somewhere
, South Carolina
07-08-2016, 06:14 PM
2005 25' Classic
New Braunfels
Thanks for the responses. I'll look into the recall and the thermocoupler fitting.
07-08-2016, 08:22 PM
2011 30' Flying Cloud
Arvada
We travel with our refrig operating on propane and from time to time the flame will blow out. I agree with others that a day of travel all not adversely impact keeping your box cold if it happens to be off.
07-08-2016, 08:31 PM
2004 30' Classic Slideout
Fenton
, Missouri
I know there have been some Dometic recall's over the years to add a larger baffle to deal with blowouts of the flame on the road. My 2001 Safari had that problem and the dealer built a larger baffle which fixed that problem. Some folks have actually fabricated some small furnace filters to fit on the door. However those need to be removed when parked to allow proper airflow into the refrigerator compartment.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-09-2016, 12:30 AM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
I had that problem and cleaning the circuit board terminal connections and adding dielectric grease solved the problem forever. The circuit board contact are not gold and therefor corrode easily. Hope this helps. Mine will stand 80MPH and semis passing.
guskmg
07-09-2016, 09:48 AM
1990 34' Excella
Waterloo
, Ontario
I recently had the exact same problem. I solved it by fitting a furnace filter (10 x 20 x01) in the opening behind the louvre door of the exterior fridge access. This prevents the flame from being blown out while travelling.
Problem solved, for me anyway.
07-09-2016, 10:57 AM
Merritt Island
, fredbrandeberry
LP on is dangerous - If you don't open the door for 8 hours on an 80 degree day the temp will go up 2 degrees.
Use wireless thermometer to tell temp - if you must run refer, get an inverter.
RV101byFred.com
07-09-2016, 11:14 AM
1974 Argosy 26
Morrill
, Nebraska
Pointless to have a refer that you can't have access to make lunch or get a cold drink while on the road. You will lose temp if the door is opened numerous times during the day.
We travel with the refer operating. And will continue to do so.
07-10-2016, 05:18 PM
2005 31' Classic
Garner,
, North Carolina
have not noticed a flame out issue on a 2005 classic with trip from florida to nc and raleigh to boone and back.
not sure what tires you are running but 70 is like WAY to fast for most of the ST tire i have heard.. the only time i see 70 is going down hill seeing another hill ahead and wanting to gather some steam to help pull up the incline..
sorta like when i used to drive a tractor trailer for Thurston Motor lines.. We had what everyone called "dragon fly" trucks. we would drag up the hill and fly down the other side.. seems the trucks were governed to 1800 RPM which limited speed to 62 MPH. We ran detroit 8v71 motors that like to run 2000 rpm to get in the power range so being limited to 1800 was an anchor.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
07-17-2016, 11:53 AM
1987 33' Argosy
Campbellsville
, Kentucky
This is why I will NOT drive with my refrigerator running when we travel:
"Not all who wander are lost."
87 Argosy 33 F since April 2010
