12-12-2003, 03:05 PM
2002 25' Classic
Oro Valley
CD player option? in 2002 Classic w/Sony
I was a little disappointed that the 25' 2002 Classic did not have a CD player built-in. It has a tape player and radio AND it is really hard for me to figure out.
Was the CD player/changer an option? Can I add it after market easily? I think it is a Sony system......can't find the book here at home; must be in the trailer in storage.
Do any of you have this system with a CD player?
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
12-12-2003, 03:36 PM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Kistler,
if it's a standard automotive stereo install, they're very easy to replace. The AM/FM cassette in my '94 was bad when I bought it. I replaced it in about 30 mins with a new Sony AM/FM/CD player.
Roger
12-12-2003, 03:53 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
cd
kistler
roger is right, not a bad job at all.
my '92 had a am/fm cassette that i replaced with a no name am/fm/cd from target. less than 100 bucks.
the wiring is very simple if you follow the instructions and look in your manual for the color codes.
another advantage to changing it out is to get the new mounting system (yours may have this already). it is called a d.i.n. mounting and requires only two small pieces of metal to remove the unit, slid alongside the radio to release it.
that means that later on you can just slide your radio out and replace it with another.
plug and play.
you may want to check if you have this mounting system already installed. your change out may be as easy as sliding out the old and inserting a new radio. no wiring!
john
12-12-2003, 08:30 PM
1993 30' Excella
whitewater
, north of cheddar curtain
qoo qoo koo juu
kistler
you can do what you want in reason....i pulled the stock sony and replaced it with a Blaupunkt that is older than my rig...i also added a cooling fan...next is a cig socket so i can stick a sony cd add on...is this a little crazy?...i dont know....i guess i cant now afford a new bp but the old one is pretty f****ng awesome as far as im concerned and my musical preference doesnt require a subwoofer....although.....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
12-12-2003, 08:42 PM
2004 25' Safari
We have a 2002 (Bambi) which has the Sony radio/tape player setup. I went to Best Buy & bought the CD holder, which has a 10 CD capacity. The Radio was CD ready, just needed the CD unit, which plugs in the back of the radio. I would think that your unit is simular. I'll check tomorrow & see if I still have the box which would have the model #, etc. It works really great.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
12-12-2003, 08:46 PM
1993 30' Excella
whitewater
cd
i bought one with an adapter that pluga into the cassette opening...relatively cheap...65 bucks with tx....now have spend another 7 bucks for a socket....
12-12-2003, 08:54 PM
Aluminut
2004 25' Safari
Hey before running out to get a CD player, consider getting a good MP3 player (iPod) and then, you get a tape adapter that can plug your MP3 player of choice (iPod) into the coach. Some newer stereos even have a plug on the outside for an MP3 player (iPod).
FWIW, you can run out an buy a CD player, but why, you gotta lug all those CDs. With a good MP3 player (iPod) you can have thousands of songs any way you like it in a small footprint.
It's what I do....I buy songs from the iTunes music store for .99, get exactly the songs I like, add songs from CDs I have and there you have it, over 15 hours of music on my iPod which is something smaller than a Walkman and I plug it right into the factory installed Sony tape player.....one unit, hundreds if not thousands of songs without all the tapes and CDs
Just a thought.....
Did I mention that I have an iPod?
12-12-2003, 09:13 PM
1993 30' Excella
whitewater
hello mr mac...
since i am not on the cutting edge of technology... and i just bought this walkman.....i guess im stuck with it... not that i mind....how many songs do i need?...just kidding......got plenty....white line fever....a sickness born deep in my soul....
norby
12-13-2003, 06:53 AM
Just a member
1978 28' Argosy 28
Lutz
Another thing to think about if you are replacing the factory unit is that if you stay wit a Sony it should be plug compatible. No wiring, depending on how Airstream wired it in.
Also if you replace it with one that has a set of aux RCA inputs on the back, then you can use them to jack in anything. Ipod, DVD Player, Video game, Even the output from the TV.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
12-13-2003, 07:17 AM
1996 30' Excella
Brighton
, Michigan
In 1996 when we ordered our trailer the standard unit was an AM/FM/Tape and the AM/FM/CD was a $500 option. The trailer came with the Sony am/fm/tape and two years later I replaced it with a Sony am/fm/cd which was on sale at local electronics store for $90. The units looked same however the plugs on the back were different, as a result I had to rewire the speaker connections.
12-13-2003, 07:49 AM
1993 30' Excella
whitewater
12-13-2003, 08:17 AM
2002 25' Classic
Oro Valley
Veeery funny, Norbert! I really like A.E. Milliman's plan....but appreciate all the suggestions.
Kistler
12-13-2003, 12:45 PM
My 93 had a Sony AM/FM/Tape but it was shot. Audio shop replaced it in less than 30 min w/new AM/MF/CD player. Now just need more amp and big subwoffer.
If you guys are Allman Bro's fans they have a new CD that's great. May just be as good as anything they've ever done, and they've done some great music over the years. The title is "hittin the note"
Man i wish I could play like that !
Don
Don Nall
93 Land Yacht (The Minnow)
