Old 05-29-2015, 05:19 PM   #1
2015 20' Flying Cloud
2015 Interstate Ext. Coach
houston , Texas
What are you towing with your AS Interstate?
Just bought a 2015 AS Interstate Grand Tour. Want to add an AS trailer for additional room/kids at the campsite. What AS model can I tow safely with appropriate hitch and stabilizers, brakes, etc.? I know the specs of the GT, but need someone with practical experience to advise; not the dealer. thnx, d.
DDTEXVA is offline   Reply With Quote
Old 05-29-2015, 06:58 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I saw another thread just a couple of days ago that included a picture of a Roadtrek pulling an Airstream trailer. The thread was: http://www.airforums.com/forums/f483...me-135569.html. It was post #33, by Beaubill.
If a Roadtrek can do it, then an Interstate on the same chassis should be able to as well, provided the curb weight of the Roadtrek isn't much less than the curb weight of the Interstate.
Old 05-29-2015, 07:22 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I couldn't tell if that Roadtrek was a 2500 or 3500 chassis. Didn't appear to have duals but maybe wheel covers hide them.
Glass half full or half empty to an engineer is the glass is twice as big as it needs to be.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
73shark is offline   Reply With Quote
Old 05-29-2015, 07:38 PM   #4
Doesn't matter. DDTEXVA has a 2015 Interstate. If a 2500 Sprinter with a GCWR of 13550# can tow a given trailer, it's a good bet that a 3500 with a GCWR of 15250# can tow the same trailer.
Old 05-29-2015, 07:58 PM   #5
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
I looked at the photo of Roadtrek pulling an Airstream trailer - it's an older model Sprinter (T1N) 2500. I'm sure the towing capacity on the older Sprinter was less than the current models.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is offline   Reply With Quote
Old 05-29-2015, 08:10 PM   #6
73shark's Avatar
Hopefully the Roadtrek isn't towing more than its rated for.
Old 05-30-2015, 03:31 PM   #7
hamiltonmj's Avatar
2013 Interstate Coach
Opelika , Alabama
I tow a 17' 1965 Caravel...the Dual wheels on the 3500 make towing a breeze for stability.
Mike Hamilton
WBCCI # 2766
2013 Airstream Interstate (Darth Vader)
1965 17' Caravel (R2D2)
hamiltonmj is offline   Reply With Quote
Old 05-31-2015, 08:11 AM   #8
Flemington , New Jersey
I use my 2013 Lounge to tow my car trailer to and from race tracks. Mostly Watkins Glen. Fully loaded with spare tires, tools, 4 full fuel jugs, full fuel load in track car, track support equipment and gear I'm pulling about 4200-4300 lbs as shown below.
Unlike my former F250 and 24' enclosed trailer which needed a weight distribution hitch, my current set up does not use any other external trailer stability measures.
I installed a Tekonsha Prodigy trailer brake controller and wired it directly into the provided Mercedes harness for a brake controller. ( you either have to find the matching harness connector to wire to the brake controller wiring into or you have to cut the Mercedes connector off and splice connections.)
Once trailer and Sprinter are connected the Mercedes ESP extends to the trailer as well.
Current set up tows much better than my old F250 with a trailer combo.
Name:	ImageUploadedByAirstream Forums1433080551.744750.jpg
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 05-31-2015, 08:38 AM   #9
The SilverSleeper
Beaubill's Avatar
2001 28' Excella
2005 25' Classic
1988 23' Excella
Daphne , Alabama
Pleasure Way
We have a Pleasure Way B Van 2500 Sprinter with a straight 5 Mercedez engine,and we pull a 1992-- 21ft Sovereign Airstream.Its the best of both worlds. We get 17mpg and if we boondocks in the heat, we stay in the van with a/c and when we boondocks in cold weather we stay in the trailer with furnace. When traveling the navigator can use the bathroom without stoping.The van has a tow weight of 5,000 lbs. The Airstream has a dry weight of 3,900 lbs and has twin axels, with the same holding tanks as a 30 ft. We looked at the Sports and the 21 came out on top .In the mountains the mpg drops to 15-16mpg and we have traveled interstate 40 without any problem, can't tell the trailer is back there. -------some people call it a "2 BR unit" and others call it a condo. Most campgrounds have a 30 & 50 amp hookup at each site and you can hook up both units if you want to.
Beaubill is offline   Reply With Quote
Old 05-31-2015, 08:40 AM   #10
The SilverSleeper
Beaubill's Avatar
2001 28' Excella
2005 25' Classic
1988 23' Excella
Daphne , Alabama
Pleasure Way
Old 05-31-2015, 09:41 AM   #11
2024 Interstate 19
Fulton , Maryland
You can safely tow any AS trailer that keeps your total weight under your Sprinter's GCWR of 15,250 lbs. I recommend you get your GT weighed fully loaded so you know how much trailer weight you can handle. For example mine weighs about 10,600 ready to roll. That means I could safely tow a trailer weighing no more than 4,650 lbs. Your GT might be a bit heavier.
I looked at the current Airstream trailer weights and you would probably have to stay with a single axel model to stay under your GCWR. If you look at older Airstreams you could have more options as the vintage models were lighter. Airstream has a great document on their web site that lists the weights of all their trailers going back to 1954.
http://www.airstream.com/wp-content/...me-Weights.pdf
Enjoy,
- - Mike
- - Mike
Old 05-31-2015, 09:57 AM   #12
Just to be on the safe side, get two weights for your van. One with all tanks empty (except diesel, which should be full), one with the fresh, gray, and black tanks full of water. Given the tank capacities of an Interstate, the difference between full and empty tanks can be as much as 650 pounds (my estimate, I haven't weighed mine lately, either).
The ideal of course is to always have the van's water and wastewater tanks empty while towing in order to maximize your towing capacity, but if you have no choice but to tow with one or more tanks full, it would be reassuring to know if— and if so, by how much— you might be exceeding your GCWR.
What would you do different if you were placing your concrete your pad again? dznf0g Winterizing, Storage, Carports & Covers 57 06-10-2015 09:27 AM
Do you actually like towing your airstream? What to expect on first tow. gomotomoto Our Community 44 10-01-2014 06:48 AM
How Many Miles Do You Have On Your Interstate? Ron_CA Sprinter and B-van Forum 40 04-16-2014 08:33 PM
Did you drive your Airstream Interstate today? Colonial Airstream Commercial Listings 3 01-13-2014 09:01 AM
New Motto: "What's next to go wrong on your trip-in your Interstate!" gmillerok1 Sprinter and B-van Forum 19 08-07-2013 10:36 PM
