Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 02-10-2014, 05:50 PM   #1
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Protecting the master cutoff switch
I have not felt comfortable with the location of the Master Battery Cut-off remote switch on the wall in front of the bathroom. In fact the first week we used it my daughter was sitting in the chair by the sliding door and accidently bumped the switch into the off position with her elbow. I personally think that Airstream should include some form of safety cover over the switch so we improvised a “guard.” We took some plexiglass, cut it and shaped it. Its not the best but it will help eliminate some accidental bumps and turn-offs.
ID:	205322   Click image for larger version
Bikerbill is offline   Reply With Quote
Old 02-10-2014, 05:57 PM   #2
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Our main switch was in under storage carpartment of our funfinder. An innocent lawnchair hit the switch and we had 18 hours of trying to figure out how we were getting home as we were boondocking and the slide was out. We now know we can always plug into the car to get a little power and we know to always check that switch first if we have power issues.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 02-12-2014, 10:05 AM   #3
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
The arm of the passenger seat, not the co-driver's seat, does a great job of protecting the battery disconnect switch in our 2013 Interstate. So good in fact that it is not easy to get to the battery disconnect switch except from the outside with the door open.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 02-12-2014, 10:58 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Co-driver? What's that? I haven't had a co-driver since I took driver's ed way back in high school, using cars that had a second set of controls in front of the instructor. If there's only one set of controls to make it go, stop, and turn, then there can only be one driver.
So I agree; it must be the "passenger" seat.
Old 02-12-2014, 11:19 AM   #5
Newbie
joemikeb's Avatar
Fort Worth , Texas
The Mercedes Benz Sprinter Manual refers to the Driver's seat, Co-Driver's seat, the drivers's side passenger seat, and co-driver's side passenger seat. As you are a bachelor you might be surprised at how quickly my wife seized on the co-driver description when she read it. She now uses the term in referring to the right hand front seat to our Volkswagens as well as the Sprinter. For spouses, or partners, the terms driver and co-driver are probably a more accurate description of the relationship between the occupants of the front seats than driver and passenger.
— Navajo saying
Old 02-12-2014, 11:38 AM   #6
UKDUDE's Avatar
Sedona , Arizona
Humm.... Where I come from we use the term "back seat driver"
Old 02-12-2014, 11:43 AM   #7
c21
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
If you run the Baja 1000 in your AI the person sitting there would be a co-driver. :-)
c21 is offline   Reply With Quote
Old 02-12-2014, 12:41 PM   #8
Wayward's Avatar
Broadway , North Carolina
Consider adding a rocker switch guard
Switch Guards
1TP1 / 2TP1 / 3TP1 srs Micro Switch Aircraft Rocker Switch Guard DFWairparts.com Aircraft Parts, Avionics, Instruments plus more
Honeywell - AML76F10T01P - Switch Accessories/Modular Parts - Guards/Shrouds - Allied Electronics
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
Old 02-12-2014, 01:29 PM   #9
Newbie
joemikeb's Avatar
Fort Worth , Texas
Better yet simply disconnect the battery cutoff switch by the door. With the door switch disconnected all you have to do is open the access panel under the lounge and manually turn the big red knob you find there. All the switch by the door does on my 2013 Lounge model Interstate does is trigger a motor that in turn rotates the switch under the lounge in back on or off.
— Navajo saying
Old 02-12-2014, 02:04 PM   #10
2010 22' Interstate
Vincennes , Indiana
You obviously have not driven with my wife.
aa9zz is offline   Reply With Quote
Old 02-12-2014, 02:44 PM   #11
c21
Now that's funny!
Old 02-13-2014, 01:34 PM   #12
BikerBill
The idea of a quick access and readily available master cut off switch just makes good sense. Our last motorhome we owned for 15 years had a master cut off switch for all batteries by the exit door and it was covered with a switch guard that had to be lifted to access off or on. And next to it was the water tank dump, also under a switch guard. I think that Airstream COULD afford to install the guard BUT alas, they don't.
Master switch / Storage question polarlyse Winterizing, Storage, Carports & Covers 1 05-16-2011 05:26 PM
Master Switch question polarlyse Electrical - Systems, Generators, Batteries & Solar 0 05-13-2011 08:17 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
3 way switch just went kaput...replacing? MonaxLisa Lights - Interior & Exterior 24 01-20-2011 04:51 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
