04-28-2017, 11:29 PM
2009 22' Interstate
St. Paul
Propane Not Reaching Appliances
My 2009 Interstate suddenly lost propane to all appliances: generator, stove, furnace, water heater. I suspect the isolation solenoid. Where is that located? Also, should you be able to hear it transition when switching it on and off from the fill location? Any help would be appreciated.
04-29-2017, 01:34 AM
Mantua
, Ohio
Is the tank empty?
04-29-2017, 04:09 AM
2014 Interstate Ext. Coach
Sedona
Check the fuse in the 12V fuse panel under the sofa. On mine it's Circuit 6, 7.5 Amp fuse
04-29-2017, 05:39 AM
2013 Interstate Coach
Waterloo
, Iowa
the solenoid is at the outlet of the tank. I can hear a metallic clank when it turns on, but little noise when turning it off.
04-29-2017, 09:08 AM
2009 22' Interstate
St. Paul
Originally Posted by avionstream
Is the tank empty?
No, the tank is not empty. It displays 3/4 full on the electronic monitor and 1/2 on the tank dial. Just filled recently.
04-29-2017, 09:11 AM
2009 22' Interstate
St. Paul
How is that solenoid accessed? From under the van?
04-29-2017, 09:13 AM
2009 22' Interstate
St. Paul
All the fuses are good.
04-29-2017, 10:38 AM
Waterloo
, Iowa
On mine the solenoid is between the tank and the side of the van, just ahead of the box containing the macerator reel. Two wires go to it. Wires are small and exposed - maybe one of your wires is broken? Appears it would be easy to replace the solenoid(without having to remove the LPG tank) if it is in fact the problem. Good luck
04-29-2017, 10:57 AM
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin
, Georgia
I've restored 9 airstreams. On all but 2 there was splits in the propane gas lines...
Therefore, I've gone total electric with solar option,
04-29-2017, 11:34 AM
2011 Interstate Coach
Garrison
, North Dakota
I had the same issue on my 2011 interstate... the switch that is located at the exterior fill point was bad. I replaced the switch with a waterproof switch and have had no further issues. If you know how to use a meter, you can check the switch by measuring for 12 VDC at the propane solenoid valve on the propane tank.
04-29-2017, 11:50 AM
2009 22' Interstate
St. Paul
Thank you. I'll try that.
04-29-2017, 12:05 PM
Waterloo
, Iowa
rel - do you recall the mfgr/part number/vendor (Amazon?) of the replacement switch? I may order one as a spare - if the price is right.
04-29-2017, 12:57 PM
Clovis
If it's not your shut off solenoid, perhaps your regulator has gone bad...
04-29-2017, 02:40 PM
2009 22' Interstate
St. Paul
I'll check that too. Thanks. I suspect the solenoid or switch, as I cannot hear the solenoid transition when operating the switch.
04-29-2017, 02:57 PM
Sebastopol
Mine makes an audible click when the solinoid is turned on. No click, no gas. My switch went bad recently so I replaced it with a toggle switch I found at the hardware store.
05-02-2017, 03:45 PM
2009 22' Interstate
St. Paul
Rel, thanks for your sage advice. It was in fact the rotary switch, the simplest of fixes.
