06-23-2014, 10:20 PM
2014 Interstate Ext. Coach
Springfield
, Missouri
Lug nut solution
After searching for weeks for a suitable lug nut for the Sprinter I believe I've finally found them. I ordered an acorn style nut with a washer designed to fit it. The lug nuts are Gorilla brand heat treated and the washers are Gorilla brand as well. I found the at a company called Brandsport in Eugene Oregon. I dealt with Eric there who was very helpful in working with me to come up with a solution. The lug nut part # is GRLA-91148HT The washer part no. is GRLA-77916 Eric's email address is eric@brandsport.com No more dealing with those caps falling off. I found one the other day in my driveway that had been run over
06-23-2014, 10:58 PM
2013 Interstate Coach
Orange County
If this works, you are the man! Thanks for sharing and let us know if it works after you receive them.
David
06-24-2014, 07:58 AM
Townsend
, Tennessee
Should that washer number be 79916? Could not locate the 77916 on the website.
FMCA # 436814
06-24-2014, 08:25 AM
2024 Interstate 19
Fulton
, Maryland
Great find - thanks for this info. How much do they cost? Need 24 to replace all the stock lug nuts.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
06-24-2014, 06:09 PM
2009 Interstate
Bethesda
, Maryland
2009 Airstream Interstate
06-24-2014, 06:37 PM
2011 Interstate Coach
Overland Park
, Kansas
A small piece of masking tape on a couple of the lug nut flats will keep them from coming off. The PO lost two in 4K mi and I've lost none in 18K mi.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
06-24-2014, 07:22 PM
2024 Interstate 19
Fulton
, Maryland
I've lost none in 32,000 plus miles, but I'm still interested in a cleaner look. However at $3 a pop with shipping it will be $72 or more to replace all 24. Not sure it is worth it since mine seem to be staying on fine. I always take them off myself, with a special lug nut cap wrench, when having any work done that involves removing the wheels.
- - Mike
06-24-2014, 08:42 PM
Springfield
, Missouri
Yes you are correct. 79916
06-25-2014, 02:23 PM
Overland Park
, Kansas
More like $104 + shipping w/ the washers.
But they do look nice.
06-25-2014, 10:14 PM
Springfield
, Missouri
I installed the new lug nuts and washers today, they fit perfectly. I've attached a couple of pictures, probably could've taken a closer shot but they look great.
06-25-2014, 10:33 PM
Overland Park
, Kansas
Is it just the angle or do they really stick out a lot farther than the stock ones?
06-26-2014, 08:40 AM
2024 Interstate 19
Fulton
, Maryland
Wow! Nice clean look. Thanks for finding them.
- - Mike
06-26-2014, 12:31 PM
Springfield
, Missouri
They do stick out approx. 1/4" farther. They are a little smaller in diameter than the stainless caps which tends to make them look longer also. I think they look good installed. I like the look of the caps as well but once I made the second trip to the tire shop I couldn't keep them on any longer and I had no intention of continuously replacing them.
06-26-2014, 03:44 PM
Overland Park
, Kansas
I suspect the tire shop was removing your lug nuts w/ the caps still on.
They do look good. It's probably the extra washer that makes them look longer than than the 1/4".
