06-29-2011, 10:44 AM
2011 Interstate Coach
Houston
Interstate checklist
I am picking up my new 2011 Mercedes Interstate next week and am beginning to make a checklist since I am not mechanical at all. I am a pilot and have found using checklists very helpful. I thought I would make one for basic startup before a trip, breaking camp, one for use before I store it short term and long etc... Has anyone done the same?
06-29-2011, 12:02 PM
Wise Elder
2010 30' Classic
South of the river
For RVs, I have found the problem with checklists to be that the order in which things are done and indeed exactly what the right thing is to do to vary from one trip to the next.
I take more of a walk-around approach and also try to maintain my rig in a constant state of readiness by never removing tools, equipment, or supplies.
06-30-2011, 06:37 AM
1995 30' Excella
Bowie
, Maryland
I have a checklist for 'consumable' supplies. This includes obviously perishable things that get removed after each trip, but it also includes checking to make sure I have enough paper plates and napkins in the camper, too. I print it out a week or so ahead of a trip, then cross things off after I verify it's okay. I have sections of things that I don't need for some trips (for example, for winter trips, I usually take an electric heater but obviously I don't need that in August), and I just cross them out.
Otherwise, it's pretty much a walk-around like Jammer said.
A pre-flight list isn't a bad idea, though - make sure the fridge is latched, make sure the gas is off, make sure there's nothing in the microwave preventing the door from closing and thus dropping all its contents on the floor (yes, this happened to me once), etc. There are plenty more - I'd walk around once or twice with paper and pencil and watch for things and write them down.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
06-30-2011, 06:44 AM
Mantua
, Ohio
Tires, brakes, engine, tranny,hitch, and lights. All safety items. If the brakes are bad or the engine overheats, or the tires blow out or the hitch brakes or the tranny quits, it really does not matter if the fridge door is closed correctly. Safety first. jim
07-01-2011, 05:48 PM
1995 30' Excella
Bowie
, Maryland
One would hope the owner of a motorhome would be keeping up with those all the time, not just right before a trip. I mean, I treat my B190 like another vehicle - regular oil changes, check the tire pressure, check the lights, etc. If I need to take it somewhere I can usually just hop in and go, like any other vehicle.
07-01-2011, 06:52 PM
2005 30' Land Yacht 30 SL
Oakland County
, Michigan
We use several check lists to varying degrees whenever we pack up and go. One necessitates a walk around when towing our Jeep four flat. Another reminds us to secure and stow everything properly so things don't become airborne or broken off when driving away.
Another one is more extensive and lists the contents of each cabinet or storage area of the MH. This one is very useful especially at the beginning of the season.
There is also a clothes list so that we don't forget essential items. Lastly, my DW has a food list that helps her to plan the menus.
Yeah, we like lists. Sometimes, I forget to go over them and that really gets my wife going, when I forget something.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
09-25-2012, 06:36 PM
2010 22' Interstate
Vincennes
, Indiana
Anyone care to share their lists?
09-26-2012, 06:09 AM
Normal
Lists are pretty individualized.
I would suggest one for clothing and personal items you don't leave in your trailer (we leave fully stocked toiletry kits in the Interstate all season) and one with ingredients for at least several main meals to get you on the road.
We always carry a tool bag with all the basic items, also extra batteries, lightbulbs, etc. Get yourself basically stocked, look around and write down and add in anything you might need while gone.
Unless you are boondocking miles from anywhere, it is always easy to find a place to pick up left-behind items. And, you will find yourself carrying things you don't really need, which can be placed on a list of what to leave behind the next time.
Don't try to hard to get it all down pat at once, it's a process and not an event. Get out there and start enjoying yourself in that new Interstate, and things will work themselves out as you go along.
Maggie
09-26-2012, 06:46 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
I strongly suspect that no two checklists would be the same. While we might start out with more-or-less identical Interstates, we each add different pieces and parts, and camp under different conditions. The pre-trip checklist for going to a KOA Kampground with full hookups will be different from the checklist for going boondocking in a national forest.
Not only that, but the contents of a checklist will also depend on your personal level of nit-pickiness. Some people would write broad-strokes general items, others would itemize every tiny detail.
I don't actually use written checklists. As I get older, I find that memory is one of those "use it or lose it" commodities, so I prefer to rely upon memory and common sense, as long as I still have (barely) enough of both for that to work. As they say, "When the memory goes, you can just forget it!"
Besides, if I relied upon checklists, and then forgot where I put the checklist, then I'd really be in trouble!
09-26-2012, 08:49 AM
Normal
You also want a few basic cleaning items, for inside and out. Also something we leave in the Interstate the entire season.
Maggie
09-26-2012, 04:00 PM
2013 Interstate Coach
Saint Louis
, Missouri
Protagonist mentioned (on another post) to include a pipe wrench for loosening a stubborn dump station sewer cap. I have encountered a stubborn sewer cap on a couple of occasions and have recently purchased a pipe wrench to add to the tool bag.
09-26-2012, 04:16 PM
From All Over
Actually, checklists can be subdivided into two types:
1 - What to bring (shopping list/outfitting);
2 - What to do (instructions).
There are numerous threads on the Forums about what to bring on a trip. Not so many on how to set up or break down a campsite.
Do we want to concentrate on one type of checklist, or take a shotgun approach and hit both of them? Brentsouth, you started this. Which would you rather see?
10-14-2013, 12:39 AM
1986 25' Sovereign
1970 27' Overlander
SoCal
, USA
Being newbies about to take a x-country trip, I'd love to see various versions of this list. First unhook this, then latch that, and so forth. All the systems, all the plugs and fuel. There's a lot to learn and remember.
10-14-2013, 09:04 AM
Flemington
, New Jersey
Agree that everyone has a a unique and distinct list. Easy way to develop is to set up camp in the driveway and set up and break down a few times. Then fine tune as one does some real camping.
Re. on board tools, look for tools that serve more than one purpose:
10 in 1 screwdriver:
Amazon.com: Klein 32477 10-in-1 Screwdriver/Nut Driver: Home Improvement
Medium sized channel locks for removing stubborn fittings, pop beer bottle caps off, nut cracker and with tape on the tips to remove the chrome caps on the lug nuts.
Channellock 440 12-Inch Tongue and Groove Plier - Amazon.com
10-14-2013, 09:21 AM
Normal
This was my thought.
But, then, I'm thinkin'......we oughta give the guy a list, here.
There really are no lessen like one's own lessons, tho, so IMO everyone should use the suggestion above, and make their own list.
We did this run-thru, writing everything down, then laminated it and used it every time for the first month or so. Be sure to have at the end of your list "retrieve and store all tools used".
Now, I handle the inside and Doug does a walk-around outside before we pull out.....but still leaves the cap to the discharge hose cubby off at the dump station on occasion, requiring an emergency purchase of one of those when we get to our next stop. Any other RV'er seeing that hose by the side of the road has himself a chuckle and remembers doing the same thing.
Travel safe,
Maggie
10-14-2013, 09:32 AM
Flemington
, New Jersey
Divide and conquer
Generally, my wife handles the inside stuff. I am tasked with the exterior set up and break down and as the resident tech geek/mechanic ensure all systems are go/no go or make them go. Only do one thing at a time and complete that task before moving on to the next. Helps keep one sane for sure.
10-16-2013, 12:28 AM
Mont Vernon
, New Hampshire
Post trip list
When we came back from a cross country trip that was a month long, I figured that we had worked our stuff and perfected the rig placements.
Before I took everything out of the Motorhome (my current 345 model), I took pictures of all the storage spots. After I unloaded the MH, I took pictures of all the stuff on my counters. I peruse those pictures when I pack to see what i may have forgotten and to remind me of what not to take!
10-16-2013, 05:56 AM
Normal
Wow, that's a great idea!
Maggie
10-17-2013, 09:55 AM
2012 25' Flying Cloud
gresham
, Oregon
pipe wrench
Try buying a large pair of channel locks for taking off sewer cap, quick to adjust and less bulk. Also,can be used in an emergency to tighten hitch ball ect.
Pete
