Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 02-10-2014, 05:48 PM   #1
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Installing FMCA plates
I did not want to mount my FMCA plate nor my GOOD SAM plate on the Interstate so I scanned both signs and had VistaPrint create magnetic signs which we now have no the front and rear.
ID:	205320   Click image for larger version
Bikerbill is offline   Reply With Quote
Old 02-10-2014, 05:53 PM   #2
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Excellant idea. I also do not want to mount the FMCA plate. Your solution is a good one!!
toskeysam is offline   Reply With Quote
Old 02-10-2014, 05:57 PM   #3
PSchw's Avatar
2005 39' Skydeck 390 SD
Hillsboro , Texas
I did the same with WBCCI number. Works real well.
PSchw is offline   Reply With Quote
Old 02-10-2014, 07:39 PM   #4
2011 Interstate Coach
Tulsa , Oklahoma
Watch for moisture under those signs. Does not do the clear-coat on the paint much good.
Keep them dry and clean.
Road Jager
Road Jager
Living On Tulsa Time
RoadJager is offline   Reply With Quote
Old 02-10-2014, 07:45 PM   #5
PSchw's Avatar
Hillsboro , Texas
Thanks good to know. I only use mine if I have to.
Old 02-10-2014, 07:54 PM   #6
BikerBill
Thanks, kept in a heated and conditioned garage when not on the road. And when I wash I remove and dry both before putting back on.
Old 02-11-2014, 05:48 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
So did I, for close to two years. Then I noticed that there was some minor discoloration of the clearcoat under the magnetic sign, and decided it was better to go bald (as in, no WBCCI numbers on my Airstream). Which is only fair, I guess, my Airstream and I are a matched set in that regard!
Installing hammock mounts? Sundance75 Interior Restoration Forum 6 01-25-2014 12:18 PM
Installing a new sub floor... sooners1 Floor Finishes 3 12-07-2011 11:43 AM
installing a dual-temp and it's sitting up top like a square on a circle toddzo Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-01-2011 06:42 AM
Texas Year of Manufacture License Plates Bambi_Bandit Title, VIN & Registration 15 06-18-2011 10:52 PM
Installing new sub-floor StPierre Repairing/Replacing Floor &/or Frame 4 01-29-2011 09:36 AM
