Originally Posted by lhsmall
The backup camera in our 2017/18 AI Ext Lounge has gone inoperable. No display for normal driving, lane changing, or backing up. We do not have any other electrical problem. We have no blown fuse or tripped circuit breaker. I've cycled the engine and the main battery disconnect without restoration. I've tried the power button on the display (rear view mirror) and the remote without success. I've checked the camera head for physical damage - none.
Any suggestions?
Since you are not getting any video on the monitor whether in normal, reverse, and/or lane changing (left or right?) then may I suggest this is not a "backup camera" issue. I assume just a mis-statement on problem description - this may just be a dead "monitor" . If nothing at all on monitor, not even option menus will display, may not be getting power? If you are comfortable getting a little deeper into this while your rig is still under warranty, I would start by checking power inputs going into your monitor (both
12v & Gnd). Since it appears 3 cameras don't feed anything to it, it's probably not a video input problem. While you have the cable harness out, if you have a small monitor, you can connect one of the V1/V2 inputs to see if an external monitor displays any input from any of the 3 cameras. This should not be hard to isolate. Save for items that can blow up, I have no issues breaking apart broken stuff, but I tend to be gun-shy when they are still under warranty
