09-14-2019, 02:55 PM
2013 Interstate Coach
Poland
, Ohio
Frustrating bathroom extension
Finally had it with the bathroom extension. How have some of you fastened it in the extended position.
09-14-2019, 03:33 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
More info please. Year, make, model?Trailer, interstate or Atlas?
09-14-2019, 04:44 PM
Waterloo
, Iowa
We made a wedge that is cut to fit at the top of the door, fitting between the wall and top of the door. We hold it there with a piece of Velcro. East to remove if we ever want to - though we haven't in years.
09-14-2019, 04:50 PM
Poland
, Ohio
2013 interstate
09-14-2019, 05:01 PM
Poland
, Ohio
Thanks Titus had some rubber wedges laying around. Problem solved
09-14-2019, 05:18 PM
2018 Interstate Lounge Ext
LV
, Nevada
What is bathroom extension? I dont think that option is in mine.
09-14-2019, 06:34 PM
2024 Interstate 19
Fulton
, Maryland
It was something STUPID that Airstream did on older Interstates, 2012 to about 2016 I think.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
09-14-2019, 07:08 PM
Waterloo
, Iowa
Alex
The wall next to the door was hinged along the side of the door jamb. The hinge let the panel swing out into the hall about 4", giving you more width at the back of the toilet - the area where one has zero use for extra width.
09-14-2019, 09:12 PM
LV
, Nevada
Alex
MIKE - Ah, ok, I glad I was spared of this.
TITUS - well, maybe AS thought an elephant would have use for extra width, but then same elephant can't squeeze through the bath door anyways, so you right that it's useless
09-15-2019, 03:45 PM
Muskogee
, Oklahoma
In my 2011 Interstate, one of the first things I did was fix that fiasco. I removed the closeouts first (looking at the door from the inside, that's the top, right-hand, and lower pieces that close out the view from the outside attached to the larger, single flat board that is attached to the hinge). I can't remember, but I think I then took the hardware and reversed it, and there was a small, about 3" x 1" piece of plywood that came from somewhere, and I used a screw into the door and the panel below it to attach it to keep the door from rattling. The door was kept in the closed position because, as pointed out, it did not substantially increase the room inside. With this fix, the toilet seat could be raised and lowered without opening the swing out door.
One of many, "what in the world were they thinking" designs.
2011 Interstate WD/Lounge (since sold).
2020 Leisure Van WonderRTB
09-15-2019, 04:18 PM
Contributing Member
Austin (Hays County)
On my 2014.5, I removed the latch and installed strong magnets that held the extension in the extended position. If I wanted to clean around the toilet area, I simply would swing the extension all the way out for complete access to that area.
Believe it or not, the magnets I installed were intended to make shoes easy to put on without tying them. The magnets had holes for shoestrings and I fastened them to the woodwork with screws through those holes. They were plenty strong for this use.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
