Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 04-02-2014, 12:18 PM   #1
2014 Interstate Ext. Coach
Miami Beach , Florida
Are TireMinders Needed?
I was wondering if I'm a complete idiot for not spending $320.00 on tire minders for my Interstate. Are they worth it and do they work well? Thanks in advance for any feedback!
ATE123 is offline   Reply With Quote
Old 04-02-2014, 12:46 PM   #2
1981 31' Excella II
New Market , Alabama
As long as you check your tires often like when you are at a rest stop or a gas station and pay attention, you should be fine. I do a walk around every time I stop. I walk around a feel the tires and rims. If one tire is a lot hotter than the rest, then you need to find out why. Also feel the rim and hub area to see if a brake is sticking or needs adjusting. You might even have a wheel bearing going bad. Also pay attention to the trailer window relative to the window frame on your tow vehicle. If there is a tilt there, then you might have a low tire or a blown tire. You can get an IR thermometer but I never use mine. I use my hand.
Perry
Old 04-02-2014, 01:20 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I don't have them, and never felt like I needed them. An accurate tire pressure gauge, an air compressor for when a tire is low (also handy for winterizing the plumbing), a plug kit in the toolbox that thankfully I haven't needed yet, and checking the tires as perryg114 described has been good enough for me for the 27 months I've owned mine.
Even though perryg114 is describing how he checks his trailer's tires, and we're driving Interstates, the philosophy and procedures are the same. Everything except what he said about the trailer window being level with the vehicle window and the trailer wheel bearings possibly going out.
Old 04-02-2014, 03:34 PM   #4
1981 31' Excella II
I also carry a tire plug kit, although I don't recommend you run a plug permanently, it gets you to where you can get the tire fixed properly with a plug patch. Any tire I have had patched with just a plug has eventually blown out. I have also had the plug patches fail. If you come out of a store etc, and your vehicle is leaning funny, check the tires. The tire monitors are like radar detectors. They don't really protect you from the cop that came up behind you and is now on your bumper. If you walk around your vehicle you might see that bulge or gash on the side of the tire before it blows out.
Perry
Old 04-02-2014, 05:54 PM   #5
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
While I've never had to plug a tire on our AS, I have on many occasions on other vehicles and never had one fail. I've looked at them from the inside when replacing the tires and the plug appears to have melted and formed a patch on the inside. I did get the tools and patches from a gas station back when they did that sort of thing.
Tried one from a auto parts store and while the reamer worked OK, the needle bent double when trying to insert the plug which is why I bought a set from the pros. The hardest part usually after finding the offending nail or screw, getting it out, and reaming the hole. I suspect that would be really tough on the AS tires.
The Sprinter comes w/ a compressor and can of sealant.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 04-02-2014, 06:02 PM   #6
1981 31' Excella II
The plugs don't do so well on high pressure tires and that goo that they use is heat sensitive and the combination of high pressure heat and time are not good.
Perry
Old 04-02-2014, 07:03 PM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I to have had good luck with tire plugs, the kind like rope with goo on them. I have found them difficult if not impossible to push into a load range E truck tire and have actually drilled the puncture out larger to be able to get them in.
I have used the plugs and 12 volt compressor on the road from time to time when I was delivering trailers. There is no place better than an RV factory yard to load your tires with screws
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-02-2014, 08:21 PM   #8
73shark's Avatar
Or driving thru a new subdivision where they are still building houses.
Old 04-02-2014, 08:57 PM   #9
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Or a motorcycle shop parking lot where we disassemble the crates bikes ship in
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 04-02-2014, 09:00 PM   #10
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
I don't have a Tire Pressure Monitoring System (TPMS), but I'm seriously considering adding one. The 2500 Sprinters and all vehicles under 10,000 GVW come with them from the factory as required by US law.
I check my tires regularly and do a walk around at all rest and fueling stops. Two weeks ago at a rest stop just east of Little Rock I discovered the inside dual on passenger side was totally flat. Tire was ruined and I didn't feel a thing on the raod. On close inspection it looks like the rubber valve stem on that inside dual failed, with a crack right at the wheel.
In one year and 30,000 miles this is the second time I've used roadside assistance. The Coach Net service for this tire change was OK, but had to wait about 2 hours since the rest stop was not near a large city. I was going to change it myself and had everything out ready to do it. Then I discovered it is really difficult to get the Mercedes provided jack on the recommended jacking point for the rear wheels, especially on passenger side. The tanks that Airstream have added to underside make it hard to get jack on forward leaf spring mount in owner’s manual. Then once you struggle to get jack in place you won’t be able to get a full stroke on that hydraulic jack since the grey water tank is in your way.
So I waited for the paid professional to do it with his air/hydraulic jack and air tools. It took him about 15 minutes.
My other roadside assist was courtesy of Mercedes back in December due to fuel leak after dealer service for fuel filter. That one was a ride on a flatbed truck in Baltimore rush hour traffic. Also involved a 2 hour wait for flatbed that was low enough to get under bridges with that tall sprinter on top.
Just saying,
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 04-02-2014, 09:54 PM   #11
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
This question is sort of like asking if a first aid kit is needed.
kscherzi is offline   Reply With Quote
Old 04-03-2014, 05:17 AM   #12
If you install the type that attaches to the valve stem, you run into a problem in the inside rear tires due to the rubber valve stem; most TPMS are designed to go on rigid stems and will cause undesired flexing of a rubber stem. If you install the type that is built into the valve stem on the inside of the tire like you find on the <10,000GVWR tires, you won't find any to fit the Alcoa wheels. There is a type that mounts on the inside of the tire, by means of a band around the rim; I'm thinking about getting that type for both my Interstate and my toad (12 sensors in all, including the spare tires) but not until I have to change out my tires anyway.
Which brings up a point that you already know, but didn't occur to me until you said that: If you have to call for a tow, make sure you tell the dispatcher that your vehicle needs a flatbed tow, is 9'8" tall (or maybe more if you have extra stuff up there like a satellite dish) and 22 (or 25) feet long, so they send a truck with a long enough and low enough bed the first time.
Old 04-03-2014, 09:14 AM   #13
paullovern's Avatar
2013 Interstate Coach
arlington heights , Illinois
I have "tire minders" on all 6 wheels. It was a problem getting the rear inside tire minders off and back on with the Alcoa wheels. We bought the AI used (one year 10k miles). At first we got a lot of false alarms with pressure doubling in a give tire then normal 15 min later. We changed all the transmitter batteries and that alleviated the alarms. I also found one xmitter with a broken battery strap and replaced it. On an unrelated issue, one of the inside rear tires was cupped making a lot of noise. We took the AI to Mercedes suspecting a suspension or shock issue. The mechanic quickly noted that we had 5 contis and one Goodrich. The Goodrich was the correct size but not "e" rated. Upon further investigation with the original owner, we learned that he had the minders on the rear inside tires mounted on valve extensions. One of which developed a leak due to the constant motion. He lost pressure and shortly later, the tire. He was 3 hrs from home so he had Tire King replace the tire with one that fit. So we now have 6 contis and tire minders that are reasonably sans false alarms.
Paul & Doris
paullovern is offline   Reply With Quote
Old 04-03-2014, 10:05 AM   #14
2024 Interstate 19
Fulton , Maryland
Originally Posted by Protagonist View Post
If you install the type that attaches to the valve stem, you run into a problem in the inside rear tires due to the rubber valve stem; most TPMS are designed to go on rigid stems and will cause undesired flexing of a rubber stem. If you install the type that is built into the valve stem on the inside of the tire like you find on the <10,000GVWR tires, you won't find any to fit the Alcoa wheels. There is a type that mounts on the inside of the tire, by means of a band around the rim; I'm thinking about getting that type for both my Interstate and my toad (12 sensors in all, including the spare tires) but not until I have to change out my tires anyway. ...
You are 100% correct don't put the valve cap type sensors on any tire with rubber valve stems. You will need ridged stems and I have found that the famous "Borg" dually kit now comes in a version specifically designed for the Interstate set-up with Alcoa and OEM Steel wheels. But I really don't like the screw-on sensors.
Here is link if anyone is interested: DL1SPAL Chrome Duallyvalve Kit
Since I'm about to install all new Michelin tires I'll get the proper valve stem installed at the same time. Being an engineer I'm trying to duplicate the OEM internal TPMS. The only suitable one I've found is from TST:
Truck System Technologies - TST 507 Internal Tire Pressure KitTST Trucking Systems
Only problem is the supplied valve stems will not work on the Sprinter. TST referred me to Bill "Borg" Falkenborg who was reported to have the proper adapter to get these internal sensors on his Dually Valve kit. I called Bill and he does not yet have the adapters developed. So I'll have to wait a few weeks to go forward. If all else fails I'll get his DL1SPAL dually stems installed and use the screw-on sensors.
- - Mike
Old 04-03-2014, 10:46 AM   #15
73shark's Avatar
I'd be interested if you find out that Borg gets his adapters developed.
Interestingly enough, the wheel in the video looked similar to the Alcoa wheel that AS uses. Could you tell if you had to program the sensor before installation or could it be done afterwards? Wasn't sure how close the sensor had to be to the monitor. Hopefully they don't have to be pre-programmed as you'd have to break down the tires when rotating. Of course you have to do that on four of the six anyway. Seeing the several cords in the picture would lead one to believe that the monitor could be plugged in.
I had to chuckle when I pictured my AS on jack stands while awaiting the turn-around on battery replacement.
As an aside, when I mentioned putting a rigid extension on the inside dual, my service adviser mentioned the risk of road debris snapping it off.
Old 04-03-2014, 03:29 PM   #16
UKDUDE's Avatar
Sedona , Arizona
Here's something I've been wondering for quite a while: how do tire minders handle the fluctuation in pressure due to temperature and altitude changes?
I have a VW Touareg that conveniently displays all tire pressures. Starting from home in a cool garage, they can rise by anything up to 6psi on a hot day. And when parked outside, pressure in the tires facing the sun will be way higher than those in the shade.
Do the minders give false alarms?
Old 04-03-2014, 04:43 PM   #17
c21
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
I have the TST screw on sensors mounted on the Dually Valves. The screw on's use an included wrench to install and remove them. Without the wrench they simply spin on the stem making them difficult to steal. The TST system is very easy to program and works great.
c21 is offline   Reply With Quote
Old 04-03-2014, 05:07 PM   #18
Ag&Au's Avatar
Port Orchard , Washington
This post basically sums it up. So I decided to quote it and make it bold. I think that's basically equivalent to a +1.
Ken
Old 04-03-2014, 05:17 PM   #19
MeandMB
Selbyville , Delaware
I, had Dually valves installed on my 2014 ext. cab from Colonial in October, as of this date no complaints, ease of use with NO lost pressure. Cost was $120.00 if my recollection is correct.
Hope this helps
MeandMB is offline   Reply With Quote
Old 04-03-2014, 05:25 PM   #20
Since both of you own trailers, not Interstates, I fully understand why you rate TPMS equal to first aid kits in importance.
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Help!! Refrigerator Access Door Needed! Melissa Hamilton Exterior Storage Compartments & Access Doors 13 01-19-2004 04:03 PM
Organization Experts Needed! Andy R Forum Admin, News and Member Account Info 7 04-10-2003 06:53 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
