Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 07-20-2012, 03:56 PM   #21
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
I have posted an image (photo section-Argosy trailers) of a WD hitch which I think is a Reese. It's spec'd to 1000 tongue weight & 12K gross trailer weight, so my 22ft argosy is well within.
It's on Craigslist for $100. Is it worth my while?
Savage68 is offline   Reply With Quote
Old 07-20-2012, 04:04 PM   #22
SteveH's Avatar
Common Sense , Texas
If it's the one I saw with the round bars, yes it will work, but is a little on the heavy duty side. That's a good price.
Old 07-20-2012, 04:33 PM   #23
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
Great thanks. I had 24 hrs to make up my mind. My research showed them at nearly $500 retail.
Old 07-20-2012, 04:56 PM   #24
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have the time spend some of it reading this tread.
1,000 lbs. bar are overkill for you rig.
http://www.airforums.com/forums/f464...ead-92131.html
2004 Excursion 4x4
Old 07-20-2012, 05:33 PM   #25
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
I understand they are overkill, but will they work or is the mismatch bad for the rig? I'm an admitted rookie to trailers of this size.
Old 07-20-2012, 05:49 PM   #26
HowieE's Avatar
Images: 12
If I am correct the only sway control offered with the Draw Tight round bar system is the Reese flat plate. It is a very poor mechanical design that requires you to unhook it before you back up. Lots of fun in the rain. Does the system you are looking at even have a sway control component?
If you are new do more homework.
2004 Excursion 4x4
Old 07-20-2012, 05:58 PM   #27
Ag&Au's Avatar
Port Orchard , Washington
There is school of thought, with quite a few proponents, that says that the stiffness of the heavier bars will allow excess road shock to transfer to the trailer from the TV causing damage to the structure of the trailer. This has been said about Airstreams, but I do not know enough about Argosy construction to guess how well it carries over.
I tow a large Airstream with bars that are rated at 14,000 #, when the trailer GVW is 10,000 Lbs. The bars are round tapered like those in your photo. MY TV is a stiff suspension 3/4 ton pickup. I have not had any damage, but maybe I'm lucky.
Ken
Old 07-20-2012, 06:09 PM   #28
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
Thanks.
The same guy had an equalizer brand rated at 400lb tongue and 4000lb trailer.
That's a bit light for my argosy.
Old 07-20-2012, 07:40 PM   #29
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
"Set Up Right"
Upgrading from a Reese friction to dual cam. I keep hearing "if it's set up right". So that I can be sure the dealer does it right, what should I look for?
Silverbee is offline   Reply With Quote
