Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 03-20-2019, 09:08 AM   #1
2019 25' Flying Cloud
Tucson , Arizona
The Ideal Tow Vehicle Would Be....
Howdy!
In the market for new truck and my 4x4 back ground has me biased for well... 4x4's! May not be the best type of truck but probably what I'll end up with.
That said what are some of the basics a tow vehicle should have?
Things such as:
Wheel size; small or large
Lift: low or high
High profile or low? Is it better to be blocking for AS of slipping under...
Drivetrain: 4x4, 2x4
Suspension: off road or street performance. Stiff or stiffer!
Automatic vs. manual. I found a model I like with manual and it has a higher tow capacity! I thought a clutch would lower it..
How much over tow weight is ideal? For instance towing a 5000 lb Airstream would you notice a difference with a truck with a 6500 rating vs a 12000 tow rating?
Not worried about brands or reliability or deals per se just the basics as a shopping tool.
Rounder44
Rounder44 is offline   Reply With Quote
Old 03-20-2019, 09:20 AM   #2
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
This has been discussed many times on this forum.Just do a search
Old 03-20-2019, 09:33 AM   #3
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
Definitely 4 wheel drive. Otherwise you will get stuck in the mud at a lot of campgrounds.
Some of the European diesel SUV's make better tow vehicles than half ton pickups. If that doesn't do it then you'll have to step up to a 3/4 ton.
out of sight is offline   Reply With Quote
Old 03-20-2019, 10:26 AM   #4
2019 22' Sport
Would be one that starts every time and fits your needs best.
Kanusport is offline   Reply With Quote
Old 03-20-2019, 10:50 AM   #5
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
With a title like that, "the ultimate" I've wondered if a C130 would do it?
Enough capacity to carry, although it may be too short for both TV and TT.
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 03-20-2019, 11:06 AM   #6
2020 Classic 33
Box Elder , South Dakota
If a C130 can't handle the length there are a large number C5's out in the Arizona desert that might be available....
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 03-20-2019, 11:43 AM   #7
2007 22' International CCD
Warms my Overkill Engineering heart to hear these ultimate tow vehicle ideas....
Old 03-20-2019, 11:45 AM   #8
PKI
PKI's Avatar
Walnut Creek , California
Ideal and available, unfortunately are different animals, because your prejudice and those of the market are influenced by the preferance of the OEMs, which is to make money.
Manual vs automatic - In the past, manual, hands down. You pick the gear and manage the change. They often had more gears available. However, the new autos (six speed to ten-speed) are very capable. Shifting on a curve was a very bad practice, but with multiple gears available, the shift change is less upsetting to stability and more effective at torque multiplication for best performance. So, if you are one of those folks who must be in control, get the manual. You will replace a clutch now and then if you are not an excellent driver, but the package is viable. If you are knowledgable enough to out think the computer, an auto will be a great solution. Some are even programmed to correctly chose the right gear before you think it's needed. Being a manual guy, I am amazed at the performance of today's autos. Try one, you may like it. I really do.
Blocking - simple answer. The lower the better, from both a profile and a center of gravity perspective. Unless you plan to spend a lot of time off road, lower ground clearance is better. Do not lift, lower the vehicle. Older designs are lower center of gravity and could be considered. TVs that meet, but do not significantly exceed, the required capacity are often lower profile and should be considered. Adjustable height suspensions are available on some vehicles and of value for dual use.
Capacity - only what you need.
Wheel size - smaller, but that is small sidewall. Tire size needs to be matched to load. Beyond that, the stiffer the sidewall can be, the better stability you will have. From a practical perspective, there is a limit to how low a profile is viable to keep pot holes at bay. A 50 series profile might be the line not to cross. The punt is simply the smaller rim and light truck 70 series tires.
Suspension - independent front and rear with wide track and rack and pinion steering. Stiff as to roll, but maybe not bounce and jounce. Assume stiff and not stiffer. Adjustable is even better.
4x2 or 4x4 - this gets more problematic. Best is 4x2 because it is more efficient and effective on paved roads. You may go to 4x4 if your use profile moves you to that decision, but understand that giving up best suspension to get 4x4 is a bad compromise. If you are getting stuck in a campground, you are staying at the wrong CGs. Disclaimer - we went with all wheel drive with torque vectoring to address bad weather travel issues. All a compromise as to best.
Brakes - best you can get. Upgrade over OEM is not a bad tactic. Exhaust brake is a consideration. Many find it saves the trailer and TV brakes. Note that trailer brakes must be applied to control sway. If you do not regularly practice that, an emergency event will not end well. Application of TV brakes in such an event is less helpful than some acceleration with trailer brake application. Bad weather TV only braking is not good either as the coach trying to pass the TV can result. So if exhaust brake use is contemplated, practice emergency actions until they are automatic rote.
Wheelbase - whatever will make a u-turn without backing and filling. Consider 120" to be the bottom of that range. Whatever length you chose, go for less overhangs and remove hitch shanks when not in use.
The ideal tow vehicle is one you own and use daily. The worst is one you have to buy and store until you tow your coach with it.
Good luck with your research. Go low and slow. Pat
Old 03-20-2019, 11:47 AM   #9
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
The one that is capable and paid for!
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 03-21-2019, 02:40 PM   #10
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
To us, the "best" tow vehicle is a versatile vehicle. Do you want a TV that's good for everyday use around town?
Everyday use was in our top three criteria when replacing our 15 year old TV. The other two top-three criteria were adequate, stable towing capacity and a luxurious, quiet ride.
For a 5000 lb. Airstream, there are lots of non-truck options. Recommend searching for threads on Infiniti QX80, Nissan Armada, Mercedes ML350 or GL450, Porsche Cayenne, etc. if these might be your best TV.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 03-21-2019, 04:03 PM   #11
Albuquerque , New Mexico
The Ideal Tow Vehicle would be...
...capable and comfortable.
Factory tow package (integrated brake controller, transmission cooler, tow/haul mode, mirrors, etc.) preferred. 4x4 has helped me avoid being stuck in muddy CGs and while boondocking.
Tow rating is important, but pay particular attention to payload for the specific vehicle (on the driver's door pillar) to ensure that you have enough capacity for your loaded AS tongue weight, driver, passenger(s), dog, and all the gear you might want to haul.
There are hundreds of choices, each with own ardent advocates. Almost as contentious a question as "The Ideal Wife would be..."
Airhead59 is offline   Reply With Quote
Old 03-21-2019, 04:50 PM   #12
Sag Harbor , New York
Thumbs up
. . . another generic best tow vehicle thread . . .
Yawn
Old 03-21-2019, 05:08 PM   #13
2019 30' International
Pennsylvania , Pennsylvania
hmmm, a 500,000 mile reliable diesel that gets 30 mpg towing, never breaks down, fitted to a 4x4 sprinter van, with the cockpit, electronics, and comfort level of a mercedes or bmw that is rated to haul 5k pounds and tow around 12 thousand pounds would get close to ideal for me.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 03-21-2019, 06:23 PM   #14
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
The perfect tow vehicle:
Pulls like a Peterbuilt!
Fuel economy of a VW Golf TDI!
Ride of a Rolls Royce!
Handles like a Porsche 911!
Off road like a Polaris RZR!
Easy to park like a Smart Car!
Priced like a Nissan Versa sedan!
Room for people like a Suburban!
That about sums it up for me!! Think I'll just keep my GMC Denali Duramax!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 03-21-2019, 08:27 PM   #15
Tucson , Arizona
Thanks Pat!
This is great!
Just what I was looking for!
With my particular needs weighed in this helps narrow (and widen come to think of it!) and confirm my choices.
I come from more rough and tumble off road sensibilities and struggle with even considering less than 32" wheels. I can hold off my desire to lift higher but even if I lose some towing performance I think having a tractor like truck a very good tool. But I'll use your list for a starting point!
Thanks again,
R44
Old 03-21-2019, 09:44 PM   #16
2007 27' International CCD FB
San Diego , California
Howdy!
Things such as:
Lift: low or high
Rounder44
It exists. I have it. Subjectively, I know people reading this are already rolling their eyes. Because most people here are truck people, domestic people, rough and tumble people, traditional tow vehicle people, and certainly not Lexus people.
You don't have to like Lexus. Or Lexus design language or styling.
Objectively, hear me out.
Wheel size; small or large - Both. To your bias of off-roading, I put 33x12.5" AT tires. Dirt, snow, or tarmac. On larger 20" wheels for great sway control, yet enough sidewall to air down for real technical "difficult rated" jeep trails as I do those. Yet enough rubber for great on road traction to hold plenty of pace on secondary single lane mountain roads, because I like to drive fast. Which I also do on racetracks with my other car.
Lift: low or high - Both. The magic of modern computer controlled hydro-pneumatic suspension. Lowers 2" for easy loading/unloading/hitching. Or lifts 3"+ for technical off-roading or racing down a desert wash. This is not your unreliable "air" suspension found in other makes. 200-300k from original suspension is typical.
High profile or low? Is it better to be blocking for AS of slipping under... 33" tires without lift. Yet lowers 1" at freeway speed for even more stability. Seriously solid stability even when getting passed by rigs/busses, whether alongside or opposite on 2 lane roads...nothing. Wind, no big deal.
Drivetrain: 4x4, 2x4 Wouldn't be ultimate without being full time 4WD. Center locking diff. Low range. Crawl control to tackle any low traction situation. Always traction for the asking. Engine braking with all 4 tires.
Suspension: off road or street performance. Stiff or stiffer! Plush or stiff. Plush as a high end Lexus sedan. Always controlled and perfectly damped regardless of load, yet still plush. Flat cornering. No nose diving. Sport damping on demand. Yet slinky and 9"+ articulation for off-road technical trails. Thank modern technology and computers.
Automatic vs. manual. I found a model I like with manual and it has a higher tow capacity! I thought a clutch would lower it.. Auto. I like manuals too. But torque converters multiply torque, with uninterrupted pulling power. Better off-road too.
How much over tow weight is ideal? For instance towing a 5000 lb Airstream would you notice a difference with a truck with a 6500 rating vs a 12000 tow rating? Whatever it is, should tow with aplomb. Like my 8,500lb rated capacity does with my 27FB Airstream. It really does.
Not worried about brands or reliability or deals per se just the basics as a shopping tool. Reliability isn't even a question. It's a Toyota Land Cruiser. Lexus. Pinnacle of reliability.
Few other things:
1) Maneuverability for days with a 112.3" wheelbase. (with serious tow stability and performance, perhaps on account of its 6250 lb curb weight and wide track)
2) Daily drivable size (I daily drive mine)
3) 400HP (enough to speed up any mountain)
4) Never needed more brakes
5) Seats 8
6) 1300lb payload (yet I've been to 1800lb with 6x people and gear towing a 1000 miles over the rocky mountains. Doesn't flinch, roll, or porpoise. Overlanders exceed 2200lb payload fully armored. UN and Red Cross uses these in 4-ton configuration for warzone duty)
Cons:
- Expensive.
- Smallish 25.4 gallon gas tank. I fixed that with an aftermarket 12.5 gallon auxiliary tank for 38 gallons on board. There's optional 40 gallon tanks available for a bladder busting 65.4 gallon 700+ mile towing range.
https://www.motortrend.com/news/2016...-new-ignition/
There's a slightly cheaper sister vehicle which forgoes the fancy electronic suspension - Toyota Land Cruiser
pteck is offline   Reply With Quote
Old 03-22-2019, 04:17 AM   #17
mikesSE's Avatar
2007 23' Safari SE
ROSWELL , Georgia
Images: 14
Hi,I'm having a DuraBurban built in Atlanta.It is an '08 Suburban 2500 with a 2500 DuraMax/Allison running gear.Look for a post on it as soon as it is detailed out.
Mike & Nancy Gore WBCCI #2914 S E Camping Unit 012 Roswell,Ga.
mikesSE is offline   Reply With Quote
Old 03-23-2019, 08:45 PM   #18
2018 27' International
Southeastern MI , Michigan
Those are amazing. You will love it!
Countryboy59 is offline   Reply With Quote
Old 03-24-2019, 02:00 AM   #19
2019 23' Flying Cloud
West Sacramento , California
I've been researching extensively on my next truck and give a nod to Ram. Just have to decide HOW much RAM one needs. I would absolutely love to have the new 2019 Ram 6.7 diesel with torque figures in the 800-1000lb range. But I don't need it.
I've found a sweet spot of 650+ lb torque in the 2010 models to be just about right. I think. On paper it looks good.
Unfortunately, the prices their asking for some of them used is within a stones throw of new 2019 2500 models.
http://www.dyeautos.com/dodge-ram-cu...-engine-specs/
The reviews for the older model on such sites as TFLtruck going up the Ike gauntlet (7% grade for 8 miles) is nice to watch as they mimic what you would be potentially hauling up such grades.
For me anything 2010 and newer seems to be a good fit. Now just have to find a great deal.
But honestly my favorite had to be the Ram 2500 Power Wagon. WAY overkill but solves all my off-road adventures.
https://youtu.be/jFX36j_5Bg8
Brandon T. is offline   Reply With Quote
Old 03-24-2019, 07:45 AM   #20
2014 22' FB Sport
Davie , FL
I tow my 28 alternately with a 3.0 diesel or a 6.7 L diesel. The 3.0 L is more than enough with 455 ft-lbs of torque. A 6.7 L diesel is overkill but it's definitely cool.
Ideal tow vehicle for 16 AI GT twin riverdweller Sprinter and B-van Forum 21 01-03-2019 09:01 AM
Ideal tow vehicle? e5earley Our Community 2 07-04-2014 02:21 PM
Would these work on a tow vehicle? Silver Threads Tow Vehicles 5 10-07-2006 03:00 PM
What tow vehicle would you suggest? Kistler Tow Vehicles 63 09-27-2005 04:24 PM
What would the least expensive tow vehicle be? RVNUTTY Tow Vehicles 13 03-10-2004 09:48 PM
