09-04-2014, 05:01 PM
#81
2015 30' Classic
Calgary
, Alberta
Originally Posted by Road Ruler
The 300 has some very impressive stopping distances. The 34' Airstream has a half dozen 12" brakes. Something to consider.
and the 300 (or similar smaller vehicle) also has roughly a tonne less vehicle to slow down compared to larger trucks...not insignificant.
09-05-2014, 08:39 AM
#82
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Yeah, 1000lbs trying to slow down 3000lbs behind it is way better than 3000lbs trying to slow down 3000lbs.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
09-05-2014, 09:14 AM
#83
2015 30' Classic
Calgary
, Alberta
Smallest Towing car
?? The truck mass has no impact on the ability to stop. The total brake force and tire grip do....the dissipation of heat also has bearing. The calculation is:
A. 4000 + 7000 = 11k
B. 6500 + 7000 = 13.5K
Vehicle B (+ trailer brakes) must slow down 13.5Klbs while vehicle A (+ trailer brakes) has to slow down 11Klbs. Let's assume the trailer brakes are setup equally, the vehicle has to make up the difference.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
09-05-2014, 09:30 AM
#84
Nomadic
, USA
Don't tell that to all the 3/4 ton guys who swear the big heavy trucks are what have the true advantage when slowing down on a steep grades.
09-05-2014, 09:36 AM
#85
2011 28' International
Chatham
, Ontario
Originally Posted by AWCHIEF
Observation: Many Americans recommend go big with TV. Canadians seem to prefure smaller vehicles. Both agree on one thing. There recommendation is perfect and how dare any one disagree. Canadians do this more tact and courtesy.
Ha ha! It's probably because gas is more expensive up here in the north; we need to think a little more deeply when planning that all important tow vehicle purchase.
I try to retain my English (and now Canadian) tact and courtesy and would never suggest to anyone that I'm doing it right when everyone else is doing it wrong. My line is "you tow how you want to tow".
I do allow myself a little, restrained grimace, though, when people tell me that "you can't tow that with that" when clearly I can. My eyelids may flicker a little with frustration when I'm told that I'm endangering other road users, breaking the law or heading for a huge law suit when clearly I'm not. Other than that I try to remain calm.
09-05-2014, 09:40 AM
#86
2012 25' Flying Cloud
Battle Lake
Doesn't matter to most of us. Your Airstream Owners Manual has braking advice that may be more useful.
Downhill and Non-level Driving
When going downhill in dry weather, downshift so that
engine compression will slow the whole rig down. Take
dips and depressions in the road slowly and do not
resume normal driving speeds until you are sure that the trailer wheels are clear of the dip.
WARNING
On slippery pavement, do not use engine drag to help slow down as this may cause the rear wheels of the tow vehicle to skid. On icy pavement, drive slowly and, if you feel the tow vehicle skidding, gently apply the trailer brakes only. This will bring the tow vehicle and trailer back into a single line. Chains do not help trailer wheels.
Doug and Cheryl
09-05-2014, 09:44 AM
#87
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
Towing is an art. And like art appreciation, there are those who know what they like.
And then there are those who only like what they know.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
09-05-2014, 09:47 AM
#88
N/A
, N/A
This comparison would be true IF there was no engine breaking component involved. Heavy duty trucks mostly use engine breaking (not breaks) to slowdown when going down hill. Chrylser 300 does not have that.
09-05-2014, 09:57 AM
#89
2015 30' Classic
Calgary
, Alberta
I'm aware of that...however, there are many 6500lb trucks that don't have alternative braking technologies....engine, jake, exhaust etc
'15 Classic
Instagram: cory_can
09-05-2014, 10:14 AM
#90
Nomadic
, USA
The Dodge Ram 1500 does have it, including in the Hemi. And it works well.
09-05-2014, 10:26 AM
#91
2015 30' Classic
Calgary
, Alberta
My Audi does too when a trailer is plugged in....gas engines don't have exhaust brakes.
'15 Classic
Instagram: cory_can
09-05-2014, 10:43 AM
#92
Battle Lake
No but they do have engine compression and a transmission to shift down to use it. Works very well, using in combination with trailer/vehicle brakes on the steepest grades.
Doug and Cheryl
09-05-2014, 10:50 AM
#93
2015 30' Classic
Calgary
, Alberta
Smallest Towing car
So do some small vehicles...my case in point. Which brings us back to the original reason for this off-chute. The large truck still has an additional 2000+lbs to slow down....at a higher center of gravity and likely less tire grip.
'15 Classic
Instagram: cory_can
09-05-2014, 11:05 AM
#94
2007 30' Classic S/O
Somewhere
, South Carolina
Really grateful that my Dodge Ram Cummins has a manual trans that I can lock into a gear uphill or downhill and also have 4, 4 piston / wheel on the AS disc brakes.
Sorry it's off of the OP's inquiry.
09-05-2014, 08:17 PM
#95
1996 34' Excella
Elberta
, Alabama
Originally Posted by SteveSueMac
It is sort of fun after a while to PREDICT the responses :-)
If you can predict not only WHAT will be said but WHO will say it, then you're a REAL rivet master :-)
I'll try to be a good boy now.
Gas engines don't need exhaust brakes, they have compression braking if the operator is smart enough to use the gears to slow the vehicle.
Diesel engine have the need for exhaust brakes and they work very well.
You just have to remember the pavement conditions, wet and icey, ist the exhaust brake very sparingly.
'Nuf said!
Larry C
09-05-2014, 08:27 PM
#96
Nomadic
, USA
Smallest Towing Car
End of debate. I win.
09-05-2014, 09:18 PM
#97
Mohnton
, Pennsylvania
Smallest Towing Car
What are the specs on this wee trailer? Is it front bed with toes out the windows?
Even I could handle towing & backing up into site with this size!
09-05-2014, 09:51 PM
#98
2006 25' Safari
St. Augustine
I believe your answer is in finding what will fit for you. I will tell you that most people who have trailers don't buy pickup trucks for the fun of it or just to spend more money on gas, etc. I NEVER owned a truck and probably wouldn't if I did not have a trailer. What really determines it all is capacities, payloads and tow rating. I would advise you as others are saying, DO NOT trust salespeople. They usually only are familiar with one figure- tow rating which is only part of the equation. Payload is critical and a totally different consideration.
Search this forum as others have said. This is an age-old topic with MANY opinions.
On braking, my F150 has electronic geared tow braking on hills- two taps on the brake and it takes over.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
09-06-2014, 06:33 AM
#99
Biloxi
, Mississippi
Smallest Towing Car
The combo I like in the photo is the yellow VW 181& trailer in the background.
MICHAEL
09-06-2014, 09:10 AM
#100
2002 30' Classic S/O
Garden Valley
, Idaho
I guess the gravel truck drivers should just use a Chrysler 300 and just add a trailer to tow. There is something called the "Law of diminishing returns" and I certainly would rather have a vehicle rated to TOW vs a vehicle rated to haul people. Like Forest Gump said "Stupid is as Stupid does".
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
