Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 01-15-2012, 10:36 AM   #21
Road Ruler's Avatar
Images: 38
Originally Posted by scf31 View Post
There is 1 important factor I havnt saw in this post, The bigger the T/V the bigger the brakes!!!
........ and the bigger the weight.
Old 01-15-2012, 12:16 PM   #22
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Numbers for My F150 EcoBoost
2011 F150 SCREW FX4 143" wheelbase (5.5' shortbed) Max Trailer Tow Pkg 3.73 rear end
Ratings:
Front GAWR 3750
Rear GAWR 4050
GVWR 7650 w/P275/65R 18 @ 35 psi tires
GCWR 17100
Max Trailer Wt 11,300
Actual Weights:
CAT scale w/full tank, 2 adults, approx 100 lbs extra cargo
Front axle 3520 Rear Axle 2800 = 6320 gross
CAT scale w/full tank etc and 25' Classic
Front axle 3280 Rear Axle 3660 Trailer Axle 5460 = 12400 gross
I plan on adjusting the weight distribution to fine tune and have actually ordered a ProPride hitch (peace of mind factor), but we towed this setup over 700 miles bringing it home, using the EAZ-Lift WD hitch and it pulled great. I will add that the disk brakes on this truck are apparently oversized and more than up to the task. I honestly think that once we have the weight distributed correctly, there won't be much we'll have to leave at home or worry about. This combination had absolutely no issue with pulling the 25' Classic up the hills on I-44 in Oklahoma & Missouri and only downshifted twice in entire trip. Gas mileage fighting a significant headwind and the hills average 11+ and once on the flats of Illinois 13 pushing 14 mpg. The truck might get better mileage, as we get some more miles on it, is was literally next to brand new for this trip. We kept the speed between 60 - 65 mph, used the tow mode on transmission and locked out overdrive. I have owned quite a few trucks, and this F150 is one sweet truck.
All of this is worth what I charged.
Rod
rbs is offline   Reply With Quote
Old 01-15-2012, 03:29 PM   #23
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Ratings:
Front GAWR 3750
Rear GAWR 4050
GCWR 17100
Actual Weights:
Rod
I wrote a post on my F150 experience earlier this year There is a way to insert a link to a post, instead of re-writing or copying it, but I haven't found out how to do that on the iPad. In any event, my numbers are as indicated below. I can understand the appeal of the 1/2 ton over the 3/4 for reasons of lower height, fuel economy and lower initial cost. Adding the Ecoboost factor in tips the scale even further, at least for those who drive the TV frequently without the TT. I will likely trade my F150 this spring and to be honest I am not certain what I will buy. It will either be a Tundra or the GMC Sierra HD diesel.
No comments from me on your choice of vehicle. The only advice I would offer would be to try to get the dealer to provide LT rated tires on your new truck.
I have an 09 F150 4x4 SuperCrew with the 157" wheelbase, 3.73 axle and max trailer towing package (11,100 lbs). The truck came with 20" P rated tires, and the door sticker states the maximum weight of occupants and cargo must not exceed 878 lbs. My axle ratings, also on the door sticker, are GAWRf 4050lbs and GAWRr 4000 lbs. The GVWR is somewhat less at 7200 lbs.
I threw out the stock tires and have since installed a set of 10 ply Michelins. I don't know how much of the truck's weight restriction was influenced by the stock tires. After five trips through the scales and several different hitch setups I concluded that there is no way to load distribute enough tongue weight to get the rear axle load under the stated GAWR. I tow a 2011 International 27FB. The tongue weight is 700 lbs I think.
The best I have achieved was with the following conditions. Trailer tanks empty, truck full of gas, two adults, two children, one dog, two bicycles in the back along with a couple of lawn chairs and a barbecue, propane tank and 5 ga fresh water jerry can. The hitch is a Reese dual cam with 800# bars and enough stress after hitch up to bend the bars slightly.
Measured Axle load at scale (versus listed GWR)
Front axle: 3902 (4050)
Rear axle: 4277 (4000)
Total truck: 8179 (7200)
Trailer axles: 5842 (7600)
Check out the sticker on your door. I have no problem pulling my 27FB; my issue is payload.
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 01-15-2012, 03:53 PM   #24
"Cloudsplitter"
Rod,
DMT makes a good point a tire up-grade would be a very good idea.
AS far as payload goes...if your comfortable with the 390lbs, it sounds like a really good set-up for you.
AS must have put the Classic's on a drastic diet, I could NEVER match that trailer weight with ours. 7640lbs, 15960 Combined.
Old 01-16-2012, 04:27 AM   #25
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Looks like you need more truck
You must have been looking at your sticker wrong, Kgs vs LBS.
I have attached my CAT scale slips and a photo of my door sticker. The truck came with Goodyear tires, which I have never had any fondness for, so they will be replaced. The scale sheets indicate that the Airstream's weight is actually right on the factories spec's, empty with full propane. From what I have read here and talking with ProPride, I won't have any trouble distributing the weight to give me a safe package. I don't plan on hauling all that much, but if things change they will probably still be building 3/4 Ton's
Name:	door sticker.jpg
ID:	148998   Click image for larger version
Old 01-16-2012, 10:59 AM   #26
DMT
DMT's Avatar
No mistake. 878# is the stated maximum payload limit for occupants and cargo.
Thanks for posting your vehicle data. As your truck and mine are essentially the same except for the trim, this proves to me that my payload restriction is the result of the stock 20" P rated tires.
Old 03-06-2012, 12:43 PM   #27
Wayward's Avatar
Broadway , North Carolina
I tow our 25' Safari with both an F250 and an F150. The F150 has alot of time on it pulling the Airstream and is getting up there in miles. It has a v6 and manual transmission. It is a great tow vehicle. Very stable. Nicer to drive around after the trailer is disconnected compared to the F250. Key F150 upgrades I made that made a big difference were high load range tires, extra leaf spring and 4:30 rear end gear ratio.
The rear gear swap offers a big difference on smaller displacement engines as they make it easier to keep the engine on the power curve. Gas mileage was better with the 4:30 gears when towing. About the same otherwise. It does OK in the mountains but we will use the f250 there if we can.
The truck you mention has way more power and far better tranny/engine controller for towing than my old f150. Go for it!
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
Old 03-07-2012, 08:21 AM   #28
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
We have a 1987 25' Soverign and tow it with a 2001 F-150 supercrew with a 5.4 engin and tow package. This past year we towed over 5,000 miles over mountians and in the flat lands with no problems. When we buy a new truck it will be the F-150 with the ecoboost .
A work buddy gave me a trailer towing DVD he bought and it really explains, in detail, all of this stuff. Your comment about mountains and combined weight is important. The video says that it is especially important in higher altitudes where less oxygen reduces engine power as much as 20%. They refer to the 20% rule - that you add 20% more to the actual figures of weight etc. to compensate for ALL towing conditions. In that scenario, I too would need an ecoboost. My 4.6 HO 3V w/ tow package, has only a 12% above margin with a Safari 25'. I believe not twenty. So higher mountain altitudes would be slow going.
Old 03-07-2012, 09:03 AM   #29
Weldon Spring , Missouri
Slow going, yes; doesn't necessarily mean you're unsafe....I would like to think that the big car companies have already considered various towing conditions as part of the process of determining the towing limit to be assigned....
fmr.capt.evi is offline   Reply With Quote
Old 03-13-2012, 08:43 AM   #30
Dacula , Georgia
I've been pulling a 33' Sunnybrook TT all over the southeast with my 2004 F150 Supercrew. My truck has 3.73 gears, 18" wheels, 10 ply (E load range) tires, firestone air bags, Prodigy brake control and an Equalizer WD hitch. Unloaded weight is 6500 and we usually ran around 7500 loaded...the aerodynamics are probably equal to dragging a billboard down the road. Anyway, we don't race up mountains, but 65-70 on the highway is comfortable. I got rid of a 99 F350 diesel 4x4 CC truck and don't miss it. I'm not saying my current truck pulls like a diesel, but it did a good safe job with our old TT.
Our interest in an AS brought me here. Great forum!
270win is offline   Reply With Quote
Old 03-13-2012, 09:16 AM   #31
"Cloudsplitter"
Thumbs up Welcome Aboard....
Interest...umm, planning a change are we?
Nice first post, getting it right/safe for YOU is what it's all about.
Old 03-13-2012, 09:17 AM   #32
Vintage Kin
Fort Worth , Texas
Being slow up the hills for an hour a year makes perfect sense if it also means a higher mpg vehicle [lower purchase price, lower operating cost] the other 8,759-hours. Put on the 4-ways and don't worry about it (as do the sheeple).
Old 03-13-2012, 11:13 PM   #33
Dacula , Georgia
Yeah, my wife and I have always been into classic cars but once the kids came along the cars just didn't fit what the girls were into...but they love camping. Every time we see and Airstream we're very intrigued...just sold the Sunnybrook...so...
Sorry for the hijack!
2012 Tiffin Allegro Bus 37
2004 F150 Supercrew 5.4, 3.73, bags, prodigy.
Travel trailer-less for now...but looking!
Towing with an F-150 Jimandrod Tow Vehicles 61 07-25-2009 01:15 PM
Ford F 150 as a towing vehicle rgentry Tow Vehicles 19 01-22-2009 06:44 PM
F-150 FX4 towing 2008 25'FB International -- Am I OK? echoroxy Tow Vehicles 20 09-18-2008 09:01 PM
Towing Safari 25 footer with F-150 4.6? TennisMan Tow Vehicles 13 04-20-2007 11:56 AM
Towing 76 sovereign with '95 E 150 rapidsraven Tow Vehicles 2 04-18-2004 10:04 AM
