Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 01-29-2013, 01:03 PM   #1
..tc , jy
Need tow vehicle recommendations.
Hello,
I have purchased a 2013 International Signature 30 with a propride 3p hitch and now need a tow vehicle. I would like to use it as a daily around town driving vehicle, and I prefer an SUV to a pickup. After extensive reading here as well as on other forums, I seem to be running in circles.
The main problem I seem to be running into is exceeding the trailer tongue weight which is listed as 880 lbs with propane but no other options. I really like the QX56 which has a listed tongue weight rating of 850 lbs. I do not anticipate us being heavily loaded for trips. Dry weight for our TT is 6737 lbs. Have not been able to get to scales to weigh....no TV yet, but am looking to rent an Enterprise truck to weigh it.
I have also looked at the Yukon XL / Suburban 1/2 & 3/4 ton as well. The Suburban 3/4 ton would probably be a great choice, but the mpg is horrendous. The Cayenne is also appealing but low on tongue weight rating and wheel base length. Plus I am unable to travel 1500 miles to Canada in the winter to have the hitch rigging optimized and reinforced as has been suggested by Can-Am. Plus, how will that affect the TV manufacturer's warranty?
I really would like the manufacturers to come up with a regular way to list their ratings so we can compare the vehicles better. Some list a single tongue weight with no qualifiers, some list 2 tongue weights depending on the presence or absence of a WD hitch, and some just say stay within 10-15% of trailer weight (if within towing weight limit). Can you load a TV hitch with a TT tongue weight greater than its rating if using WD hitch? Or does this apply only for specific models, such as stated in the Escalade specs (600lbs w/o WD and 1000 lbs w/ WD).
I am not sure exactly how to measure tongue weight. For me, is it just 880lbs or is it 880 lbs + 200 lbs for the 3p hitch = 1080 lbs? Or do I have to use a Sherline scale or can I use a CAT scale?
What if the tongue weight for your TT is > TV tongue weight rating? If this TT/TV setup is then weighed at a CAT scale, and the calculated tongue weight is within towing specs for that specific TV, can you assume that you have met the manufacturers requirements for tongue weight or is this a misleading measurement?
If OK to tow, how do you predict the measured tongue weight before weighing it? I don't want to purchase a vehicle only to find out later when weighing it on the scales that the vehicle cannot pull the TT within given specs. I suspect few, if any, dealers would allow you to tow your TT with their vehicle on a test ride.
Of course to add to the confusion, there are potential liability issues, anecdotal experiences, and of course, personal opinions.
Anyway, any suggestions are greatly appreciated. One more thing...I do not live in a mountainous region and would be making relatively few trips up/down steep grades. Thank you.
QuickAg is offline   Reply With Quote
Old 01-29-2013, 01:58 PM   #2
My two cents is that you need a long wheelbase SUV for a relatively heavy 30 foot trailer. With a properly set up weight distributing hitch, tongue weight is spread onto all four wheels and the issues are towing capacity, gross vehicle weight (including the tongue weight) and combined gross vehicle weight.
Ford, GMC and Chevy all make a long wheelbase SUV with a tow rating big enough to handle your trailer.
Like you say, the 3/4th ton Chevy and GMC's have big 6 liter engines which would give you plenty of power at a fuel economy penalty.
Half ton Denali and Esculade SL's have the hot Cadillac engine with more than enough power to pull your rig and have self leveling air ride suspensions as well. Even used, these vehicles are expensive.
Any big SUV is a pain to park and drive downtown.
Your other choice is to get a used diesel truck or Excursion an use it as only a tow vehicle. If you shop carefully, you could get a good one for about $15,000 and drive a smaller cheaper vehicle as a comuter.
handn is offline   Reply With Quote
Old 01-29-2013, 02:37 PM   #3
"Cloudsplitter"
Thumbs up Welcome Aboard....
My baseline advise...take the factory tongue weight and add 400lbs.
Most accurate TW....load the trailer as used, full FW and LPG tanks and provisions. Measure static un-hitched weight at tongue ball socket.
You can use the CAT scales. Weigh the TV str and drive axle, hitch and re-weigh no WD, str, drive and trlr axles.
POI...we are very happy with our 2500 2006 Suburban.
Old 01-29-2013, 02:44 PM   #4
Pat Conway's Avatar
When you want your vehicle to be both a TV and a daily driver you run the risk of not being satisfied with it in either regard. The twin-turbo Toyota V8 Diesel SUV would meet your compromise, but it's not available in America. We just returned from Australia where we saw many in use over there pulling larger trailers.
I know you say you don't want a pick-up, but a 3/4 ton turbo diesel GMC, Chev, or Dodge would best fill the bill for you in power to tow, mpg, and overall towability. Even the rolling hills of Florida will have you craving enough power. Unless you are not planning much towing, or it's going to be an extra bedroom parked in the back yard, you bought a big, heavy trailer and when you hook up and take it out you won't really be happy with minimal performance.
We started pulling our l988 25 ft A/S tt with a 1999 1500 suburban. Five years ago we acquired our GMC 2500 turbo-diesel(duramax). It's great, has seating for 6, crew cab has folding back seat for extra dry cargo.
I live in Tampa and would be glad to help you pick-up your trailer and let you experience first hand the Duramax. Incidentally, this is a good time to get a hefty discount on any unsold 2012 models of Chev, GMC, or Dodge trucks.
Feel free to PM me at wpconway2217@yahoo.com. Pat
Sun City Center, FL
1988 25' Excella
Pat Conway is offline   Reply With Quote
Old 01-29-2013, 02:46 PM   #5
Columbus , Ohio
Dude - you are really out of date. The market for SUV's has been to down size and go to unibody. That started about 5 or 6 years ago. The SUV market is really not targeted at people that want to lug around 30' trailers with over 800lbs. of down force at the bumper.
Lol - I would like to tow with my Honda Accord.
But no - I 'need' a dreaded truck. A machine that is designed and built to lug heavy trailers around. If you have your heart dead set against a truck that now rides nice, has heated and cooled seats, sat radio, is comfortable, carries 5 people, gets better mpg than an SUV, and oh, by the way can also tow your trailer then:
Look at ...humm, let me think....humm, maybe the pre uni-body big SUV's. Ford Excursion, Expidition, maybe the heavy duty vans from Chevy or Ford.
There really are not many SUV's anymore that I have seen that can carry the hitch weight.
Good luck.
tuffr2 is offline   Reply With Quote
Old 01-29-2013, 03:05 PM   #6
"Cloudsplitter"
Thumbs up
Oh no here we go....
I see a trip to C eh n eh d eh on the horizon, eh
Old 01-29-2013, 03:27 PM   #7
2005 19' Safari
GLENDALE , AZ
If you can afford a new 30-foot Airstream, I don't understand why you would now scrimp on the tow vehicle. Personally, I'd just buy a 3/4-ton crew cab pickup and be done with it.
If you want a good in-town commuter with excellent fuel economy (characteristics that don't exist in a vehicle that can satisfactorily tow a 30-foot Airstream), then buy a Prius, too. That way you'll get the both of best worlds, heavy-duty towing capability and excellent city handling and mileage, attributes that you won't find in a single vehicle.
Old 01-29-2013, 03:47 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
What do you drive now? Trading seldom solves economy issues. Maybe a combination of what you have and a late model work truck (without bells and whistles) dedicated primarily for towing would be a good solution.
doug k
Old 01-29-2013, 06:02 PM   #9
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
An older Ford Excursion V-10(it's on an F-350 frame/springs) and a Smart Car is your best combo. If you average the mileage, you'll be way ahead of everyone else at the end of the year.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 01-29-2013, 06:29 PM   #10
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
Let's get ready to rummmmmble!!!!
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 01-29-2013, 06:51 PM   #11
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
I won't fall for the bait. I won't fall for the bait. I won't fall for the bait. Oops. Fell for the bait.
Jim Flower is offline   Reply With Quote
Old 01-29-2013, 06:51 PM   #12
monkeypants's Avatar
2009 27' FB Classic
Smithville , New Jersey
I'm Lucky
I say I'm lucky because I don't drive that far to work. I have a smaller second car that the wife drives for better mileage. I DID NOT LIKE THE PRICE OF THE TRUCK!(Silverado 2500 crew cab diesel ) Let's be clear about that. But I didn't like the price of the camper, either. But when I'm driving down the road pulling my dream to my next adventure, I forget gas mileage, cost of the truck, DEF fluids and the like. We are enjoying the ride. No swaying, no white knuckling uphill or down. Just food for thought. Cheers.
monkeypants is offline   Reply With Quote
Old 01-29-2013, 07:02 PM   #13
2013 30' International
Topeka , Kansas
Traded in my 2010 gas F250 for a 2013 diesel F 250 and its a world of difference. The ride is great and I drive this around town more than my 2011 super charge RR. Even my wife notice the better ride. After hard negotiations I got it lower than invoice.
2club is offline   Reply With Quote
Old 01-29-2013, 08:40 PM   #14
Travel Bird's Avatar
2012 27' FB International
Denver , Colorado
We were originally going to purchase the 30' and it was confirmed by Andy Thomson of CanAm that we could tow it with our Ford Expedition with the Hensley Hitch. We bought the 27' FB and adore our Expedition as our TV. Good luck!!
Anna
Blog: Glamper~An Airstream Diary
www.glamperanairstreamdiary.com
WBCCI #4846, WBCCI DenCO Unit
Air #62992
Travel Bird is offline   Reply With Quote
Old 01-29-2013, 08:53 PM   #15
pappy19's Avatar
I was going to say that the new Ford Expeditions set up for towing and the 3.73 rear, is about as good of an SUV combo you can get without going to a 3/4 ton like the Burb. The last Expedition we owned got decent mileage and that was before the new 6 speed tranny. Might be a good match for you.
Pap
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Old 01-29-2013, 10:13 PM   #16
Columbus , Ohio
2club - Wait unit a year goes by with your 2013 F-250 diesel then see how you like it. My bet - you will like it even more!!! Today's trucks are nothing like trucks even 5 years ago.
A/S trailers are not light trailers.
Why do so many A/S people hate trucks?
Old 01-29-2013, 11:15 PM   #17
dkottum's Avatar
tuffr2, I'm not so sure A/S people hate trucks, but we do have a choice, unlike you fifth wheelers who do not.
Speaking of fifth wheelers, why do we see so many who full-time and snowbird have a compact car as an accessory to their towing setup? That may help answer your last question.
doug k
Old 01-30-2013, 12:58 AM   #18
2008 31' Classic
Lake Charles , Louisiana
We towed our 31 ft. Classic with a 2007 Expedition EL up until March of last year. Then I purchased the 2012 F-250 diesel. Best move I ever made. The Expedition always had plenty of power but lacked in stability at times. I could have added a Hensley hitch but decided that would not address all of the shortfalls. We love the F-250. But ours is not a 'runaround' daily driver. It pretty much only gets out when I need to tow either the car or camper trailer. Wish you luck in your search.
Steve & Mary is offline   Reply With Quote
Old 01-30-2013, 06:32 AM   #19
Road Ruler's Avatar
Images: 38
I won't fall for the bait. I won't fall for the bait. I won't fall for the bait. Oops. fell for the bait....too!
Big diesel pickup VS mid sized, unibody SUV.
Old 01-31-2013, 06:45 AM   #20
asianmack's Avatar
2011 19' Flying Cloud
Chicago , Illinois
2014 Jeep Grand Cherokee Diesel:
2014 Jeep Grand Cherokee| Fuel Efficient Luxury SUV | Jeep
"drive up to 730 miles on one tank+ and tow up to 7,400 pounds"
I'm saving my pennies too!
Airstates, a better brag board. Beautiful adventure checklist for your travel trailer. https://airstates.com
asianmack is offline   Reply With Quote
