Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 07-25-2016, 08:18 AM   #21
2015 25' FB Flying Cloud
Meadow Vista , California
Has anyone had a problem with the GM reducer sleeve?
SilverSinbad is offline   Reply With Quote
Old 07-25-2016, 08:23 AM   #22
dznf0g's Avatar
Oswego , Illinois
No, reducers just allow for additional stacked tolerances ("slop") and make it more difficult to achieve proper head tilt and keep noises down. I've used them on a number of my GM 2500 demos and have had no "problem".
-Rich-
Old 07-25-2016, 12:46 PM   #23
Tom T
Tom_T's Avatar
Orange , California
We've been renting 3/4 ton F250 & RAM 2500 pick-ups from Enterprise Commercial Rentals to tow our 1960 Avion T20 (which at about 3000# wet & loaded is "TV overkill"), as we decided on what TV we wanted, & are now searching for our our mid-size SUV V8 TV (Cayenne S or maybe equiv. Toyota/Lexus).
Some have had the 2.5" receivers with the sleeve to mount our 2" stinger for our Hensley Cub, with no problems. Although, I wouldn't see any reason get a 2.5" on a TV, unless you need it for the trailer size or load.
In most cases the issue with some truck mfgr., OEM & aftermarket 2" hitches & their attachment to TVs, is that they're not properly braced &/or attached to the TV frame/unibody to properly transfer the weight forward from a WD hitch, or have some weak weld point - any of which can be remedied by a good welder/shop.
I've seen many topics on here about how to reinforce &/or extend various of the OE/other hitches, including the GM/Chevy 2" noted above. Maybe do a search for that subject.
Cheers!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
It's Thursday, and I like my Airstream because...... 2airishuman Community Polls 2183 09-19-2018 09:34 PM
Replace water tank just because? grayling Fresh Water Systems 13 05-12-2015 05:47 AM
Just because you own an Airstream:$$$$$ ROBERTSUNRUS Off Topic Forum 86 01-03-2012 06:10 PM
'77 Argosy, should I jack because tires flat? saxonsraven1 Mechanics Corner - Engines, Transmission & More... 1 01-26-2004 02:18 PM
